DIY HELP - the rubb...
DIY HELP - the rubber strip between window and frame
6 Users
2 Reactions
What’s it called?
Replacing some rotten wooden beading outside of a window pane. Google skills have failed me. What’s the rubber strip that would sit between wooden bead and the glass called?
I assume it’s there to provide some weather proofing as well as cope with wood expanding/contracting with the weather.
Tried lots of searches but nothing appearing looks like what I need.
Posted : 26/08/2024 8:47 pm
Could be a wedge bead
Posted : 26/08/2024 8:50 pm
Only showing wooden beads.
That search led me to window gaskets but they all seem a particular contour. I think I just need a plain flat strip/roll of rubber or whatever material it’s made of.
Posted : 26/08/2024 9:01 pm
Flexistrip? Basically mastic on a roll used to glaze wooden frames, modern alternative to putty. Must be 20 years since I used it, but still got a box in the garage...
IMG_20240826_212224904_MFNR
Posted : 26/08/2024 9:25 pm
Whichever seal it is, I’d expect these guys to list it.
https://www.reddiseals.com/
Posted : 26/08/2024 9:36 pm
Flexistrip that looks like the stuff, thank you steveb ?
Posted : 26/08/2024 9:42 pm
Clear glazing silicone. Soudal, Dow 799, etc.
Get hardwood glazing bead, well worth the extra ££
Posted : 26/08/2024 9:50 pm
angrycat and angrycat reacted
Glazings normally on foam tape...
My timber sunroom is. Against the glass and beads I've trimmed shitty silicone etc out taped and used ob1 clear.
Posted : 26/08/2024 10:31 pm
