Circ pump is running permanently since its last full disinfection at the weekend. Everything else working fine. Checked filter cycle and it's not on permanent. Any contacts or any ideas?
Have you checked the jizz filter?😂
aye, spunkaway.com is the place for replacement parts and de-clogging products
Sounds like a blocked spunk flange.
Michael Barrymore will know someone
My wet end is dribbling.
It really is. Just waiting for the new seal to arrive.
I do all my own maintenance,always have. They aren't that complicated.
Obvious, turn it off, leave it a bit, turn it back on.
Ha e you asked the supplier of that model has a known problem? Some do. So.e have old model pumps that are unreliable so might just be that.
If your tubnisnt that old they might send someone out cheap to have a look.
Most visits from HTA start at a couple of hundred quid! See thread on charging a fair rate!
Our circulation pump is always on. It's not a problem...
When you call these things 'dirty sex ponds' is it the sex that's dirty, or the pond?
Asking for a friend
When you call these things ‘dirty sex ponds’ is it the sex that’s dirty, or the pond?
Asking for a friend
If you go to the environment agency website, it will all become clearer! Or more likely, opaque 😶
Serious answer. What turn the the pump on and off? It can't be very complicated. Only one or two sensors. So you have a schematic?
Maybe pumping through the heater to keep it warm? Check what temperature it is set at, and check how hot the water actually is.
Circ pump will normally run when heating then cut out, it also runs during filter cycle which can be set for various intervals. Tub is calling for heat correctly I believe as the heat light seems to be tieing in with temp input. Tub is run by balboa brain so good quality kit.
As for your wet end good luck with that I ended up replacing both mine entirely rather than the seals as that looked a bastid of a job.
Engineer? You mean dirty sex pool fitter.
Have you blown a seal in the tub?
You need a Pissness Analyst.
