Desire battery issu...
[Closed] Desire battery issue
8 Users
My battery is taking an age to charge...capacity is down since new but not drastically recently. 15 months old.
Time for a new one?
Posted : 23/12/2011 5:42 pm
A 15 month-old smartphone battery, it'll be drained imo.
http://www.nicecans.co.uk/htc-phone-accessories-batteries-c-67_44_93.html
TM
Posted : 23/12/2011 7:15 pm
OK so the new battery makes no difference...warranty job?
Posted : 14/01/2012 8:10 pm
Fully drain it, fully charge it, rinse and repeat.
Posted : 14/01/2012 8:16 pm
Got the t shirt already!
Posted : 14/01/2012 9:11 pm
My mates went back for the same fault recently. Writing this on a HD that's actually pretty good. On Android 2.3.5
Posted : 14/01/2012 9:25 pm
my HTC Legend is on a 20 month battery and still holding a good charge.
Posted : 14/01/2012 9:27 pm
My desire is 20months and still holds fine too. I have been thinking about a new one as a friend bought an aftermarket battery that gives him 2days + charge.
Posted : 14/01/2012 10:17 pm
Which one did he get? I'm not aware of a straight replacement for the original Desire (that isn't silly money).
Got an Anker (yes, yes) battery for the Sensation, it's very very good.
Posted : 14/01/2012 10:22 pm
Hmmm....wonder if I can get a new phone out of this?
Shame I had to btw a new battery to find out...internet advice in "incorrect" shocker!
Posted : 14/01/2012 11:12 pm
Worth a punt regardless. Ring your provider before you buy anything.
Posted : 14/01/2012 11:19 pm
Ta...odd thing is it's not a consistent fault. Will speak to Orange...guess I'll have to get something cheap as A spare while it gets investigated.
Posted : 15/01/2012 7:45 am
Well...Orange said it's not their problem as it's out of the 1 year warranty and HTC would likely tell me to ram it as it's a wear and tear issue on the charging port (WTF?), HTC said do a re-set, which, oddly, [i]may[/i] have worked!
Posted : 17/01/2012 12:23 pm
PSA for those interested (prob only me!)
Apparently your Desire charging cable has certain connections in the micro usb soldered together, and so can draw more current (WTF?), charging with the proper cable seems to work better and weirdly gives a "better" full charge than the cheap cable (WTF Squared)
Posted : 07/02/2012 1:16 pm
 Bez
the first wtf is fairly common; the USB standard specifies a certain current limit and many devices identify faster chargers by the short on two of the pins. bit of a hack but it's widely used
Posted : 07/02/2012 1:55 pm
If only you'd been here a month ago 😉
Posted : 07/02/2012 1:57 pm
As I understand it, the proper cable does give you a faster charge.
Same with the car charger. It charges at a higher rate than cheap aftermarket ones. I got a genuine HTC charger for the car to plug its in when using Google Nav.
Had read reports of nav discharging battery even when charging when using a non HTC lead, where's the proper lead will power the device while using nav and charge the battery...
Posted : 07/02/2012 2:30 pm
