I plan to paint the inside of a porch, which is currently bare brick. It's enclosed, so sheltered from the weather, but not heated. Would a coat or two of diluted PFA then two or three coats of emulsion paint work ok? Emulsion because I understand it's porous.
Posted : 08/09/2011 6:39 pm
Ac oat of watered down PVA (not sure about PFA) then Vinyl based emulsion should work very well. If you don't use PVA first the bricks soak up a lot of paint. We used to paint the lines on the track at Halesowen cycling club with mat vinyl emulsion and they lasted years, outside in all weathers.
Posted : 08/09/2011 10:15 pm
Thanks, and you're right, it's PVA.
Posted : 09/09/2011 9:55 am
