Data transfer from ...
[Closed] Data transfer from edge 25
I have paired my edge 25 to garmin connect mobile on iphone 6 but i cannot work out how i sync my last 2 rides. I cant even find anything on the web. Can somebody confirm this can be done and if so, how?
Posted : 10/04/2016 10:21 am
Assuming you have Bluetooth on and it is pairing ok. Make sure Garmin Connect is on. Go to 'more' and scroll down to devices. This should show you if it is connected and you will see whether it is syncing. You might find that the sync isn't working. I don't know why it doesn't but mine doesn't either. It gets halfway through the sync and then drops it. That applies to both an Edge 1000 and a 25. I assume this is Garmin software doing what it does. Sorry I can't be of any more help.
Posted : 10/04/2016 10:40 am
That is helpful imnoyverygood as i couldnt even find where to look to see/do the transfer. I will give it a go.
Posted : 10/04/2016 10:49 am
It has now worked but had to turn off autoupload and then turn back on again and that did it. Usual standard of garmin software, i think i prefer usb and laptop connection!
Posted : 10/04/2016 10:56 am
Looks like a common fault then as my 25 is the same.
What I can't work out is if you turn off auto upload, where is the manual upload via blutooth function?! The only manual way of doing it is usb and 'putter as far as I can see.
Posted : 10/04/2016 11:06 am
Fettlin - though exactly the same as you. I am going to stick to plugging it in.
Posted : 10/04/2016 2:42 pm
