Damage on a brand n...
[Closed] Damage on a brand new carpet!
Had a carpet fitted today. Got home to find a loose thread, under the thread, you can see the backing weave has a cut in it.
I'll call them in the morning and I'm sure I'll get it sorted.
My question is, does anyone know the trade? Am I likely to be offered a new piece or a patch repair? If the offer a patch repair, should I accept it or insist on a new piece? (landing, less than 2 x 3 and two or three of the top steps).
Posted : 04/03/2015 8:13 pm
 nuke
Last carpet we bought (from Carpetright) was for a 4mx3m bedroom: was fitted but had a damaged thread, phoned manager, he came and had a look and they replaced the whole carpet
Posted : 04/03/2015 8:25 pm
 JoeG
I think that I'd want the landing carpet piece to be replaced. As a high wear area, I'd be concerned about a spot repair there.
I have hardwood floors, btw... ๐Ÿ˜‰
Posted : 04/03/2015 8:26 pm
 kilo
Last we had was a complete replacement as well, mark in the middle of the carpet, they took it up with the manufacturers once they saw it was a manufactuing fault rather than an issue caused in their storage or fitting. Would a patch repair be invisible? We've had a joined carpet and the seam is visible.
Posted : 04/03/2015 8:30 pm
United Carpets have replaced our carpet..................... Twice!!! We had the carpet fitted in 2012.
Our living/dining area was too large for one roll so needed a join. I had them out 3 times due to the join separating.
The 3rd time, the fitter said the join had been done incorrectly and the carpet had been cut too short.
We got a new carpet fitted and the join went again!!!
As it turns out the carpet we were sold was not suitable for heat seam sealing!! So we had another carpet fitted last Dec and fingers crossed that's the end of that.
So you should get a new one!!
Posted : 04/03/2015 8:34 pm
Cheers folks. At least I know what I'm shooting for when I call them tomorrow.
Posted : 04/03/2015 8:41 pm
I love coming on here. It's like looking at what life is like in my future.
I'll choose laminate!
Posted : 04/03/2015 9:00 pm
You should have seen the laminate that was in here from the previous owners. That's the reason we've just fitted carpet.
Posted : 04/03/2015 9:55 pm
Loose thread, worked at a customers hhouse , she had carpet fitted that day, we planned door at base to clear carpet, childminder stayed in afternoon to look after small child, small child spotted loose thread, and thought it was a good idea to pull loose thread, which made a hugebald patch up and down carpet, result carpet ruined, and childminder sacked for sleeping in stead of child minding child, also a vacumn cleaner can hook a thread, if its got a rotary brush result anguished scream off vacumn and damaged carpet.
Posted : 04/03/2015 10:53 pm
Given that it's a piece of carpet that neither of us have ever walked on, I'm not inclined to believe it's an unlucky pulled thread!
Also, we're well aware not to have the beater bar engaged on the vacuum cleaner for a loop style carpet.
Posted : 04/03/2015 11:35 pm
Will probably be the most middle class ing I see written down until I check back on here at lunchtime!
Posted : 05/03/2015 7:34 am
Loop pile
sounds like the fitter has nicked it with his knife
bodgeable if it was an old carpet you need it replacing for sure
and dont get a cat
Posted : 05/03/2015 8:29 am
Cheers all. Only took a couple of minutes. They came out, saw it was cut and said they'd order in a new piece. Nice and simple.
Posted : 07/03/2015 10:40 pm
 JoeG
Onzadog - Member
Don't be all smug till the new piece is installed successfully! ๐Ÿ˜ก Lots of things could still go wrong... ๐Ÿ˜‰
Posted : 08/03/2015 5:39 am
