Sorry if it's already been discussed, but are curved screen tvs worth it? Or should I stick with a similarly priced flat screen because it's a just a bit of a marketing gimmick? (Hello 3D)
Its not necessarily a gimmick but its not for everyone / every living room. You ideally have to view them from a specific distance and dead centre to get the immersion effect, but when set up properly and viewed from the right angle it is fairly impressive.
Its a bit like having your own iMax cinema when set up properly. So definitely one for the cinephiles to check out, but for regular viewing in a typical family home I'd go flat screen.
4K / UHD is a different matter though. We've just bought a new TV and stuck with standard 1080p because 4K seemed excessive for us at the moment but unlike 3D / curved, 4K is slowly establishing itself and it might be worth futureproofing yourself.
A curved one will be a bugger to hang on a wall...
As devash says, it has a viewing hotspot, so a flat panel is far betterer for general viewing in a regular room.
They are more expensive and thicker than a flat TV - I saved about £70 (and gained three inches - wahey!) by not buying a curved Samsung recently - same spec etc.
