crack for excel spr...
[Closed] crack for excel spreadsheet
10 Users
How do I crack a password in excel? There are loads of programmes on the WWW that come up when I google this however I'm afraid of downloading an .exe file that might be virus/spy/etc.
Chris
Posted : 30/01/2009 4:26 pm
You're right to be concerned
Posted : 30/01/2009 4:27 pm
Type away on the keyboard really fast whilst looking at several monitors, works every time in the movies.
theres a great VBA patch for doing it, let me see if Ive got it somehwere...
easiest way to crack the password, is to find the owner and ask them.
Posted : 30/01/2009 4:28 pm
sounds a fair swap. How many rocks?
Like Stoner says, there's some VBA code that you stick in a button that tries every possible combination to get the password. (The password you type is converted to a much shorter string of text, so it doesn't take long.)
Posted : 30/01/2009 4:29 pm
Have you tried 'password' or 'letmein'
Posted : 30/01/2009 4:49 pm
sorry cant find it. Just go and download it yourself and if your nervous run it on a quarantined computer.
Posted : 30/01/2009 4:55 pm
 deus
i've got the VBA somewhere
i'll have a look
Posted : 30/01/2009 5:50 pm
 deus
ah ha found it
Posted : 30/01/2009 5:53 pm
 deus
it used to work, although several emailings may have changed the layout a bit.
Sub PasswordBreaker()
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
ActiveWorkbook.Sheets(1).Select
Range("a1").FormulaR1C1 = Chr(i) & Chr(j) & _
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
Then run it when the protected worksheet is selected
(Tools-Macro-Macros). This should unprotect any
protected worksheet.
Posted : 30/01/2009 5:56 pm
 deus
seems odd that it doesn't punt you back to the main forum page any more when you've posted, anyway.
Posted : 30/01/2009 5:57 pm
that didnt work. The file is locked so that VBA cannot be used (not that I'd know how to use it)
C
Posted : 30/01/2009 10:05 pm
 Mr_C
Download OpenOffice from [url= http://download.openoffice.org/ ]here[/url] install and load the spreadsheet - this has allowed me to edit a password protected spreadsheet in the past.
Posted : 30/01/2009 11:08 pm
 deus
i wonder if those "_" are supposed to be there, maybe emailing that's added them, would probably make more sense.
Posted : 31/01/2009 12:29 am
