Cost of fitting a s...
[Closed] Cost of fitting a shower - any idea?
We are looking to get an electric shower fitted. Any idea of the ballpark cost of this?
Posted : 19/09/2010 5:12 pm
 ojom
*sharp intake of breath and puts hand on hips*
"welll......."
Posted : 19/09/2010 5:19 pm
£483.64, according to the invoice I've got in my hand right now.
A big chunk of that was fitting a new consumer unit to supply it, as I'm in a house with wiring dating back to the late Jurassic.
Posted : 19/09/2010 5:21 pm
Has to be cheaper than the £750 estimate we were given off the first place we called.
 ojom
is it an cooncil property?
if so, they may well have a department for that type of thing.
Posted : 19/09/2010 5:24 pm
Housing association. They will let us do whatever we want to the place, but dont have any reasonably priced contractors.
Posted : 19/09/2010 5:26 pm
 ojom
Hmm. I see.
do the 3 quotes pick the middle one thing.
Posted : 19/09/2010 5:31 pm
http://www.mybuilder.com/ of any use to you perhaps?
Posted : 19/09/2010 6:10 pm
How lonhg is a piece of string?
Is the pipework near the location of the shower - mains fed not tank fed cold water supply?
How near is the fuse box / consumer unit? does the fuse box have enough capacity for an electric shower?
running a cable can be very time consuming thus expensive and so can running the pipework. Fitting a new consumer unit can be farily expensive as well
Posted : 19/09/2010 6:12 pm
You could fit bath shower mixer taps instead which would be cheaper as less work involved. Just need to balance the pressure of the hot and cold with a pressure reducing valve. If you have a combi boiler fitted then you will get quite a drenching when you use it, instead of a dribble. 😀
Posted : 20/09/2010 6:48 am
I have both an electric shower and taps if you are interested. email in my profile
Posted : 20/09/2010 6:49 am
re: soops. Online I found BES in birmingham had pressure balancing valves with 1/2" BSP connections for about £40. Fitted one in line with my bath/shower mixer the other week. Makes a real difference when someone flushes the toilet - no more 50C surprises.
Posted : 20/09/2010 7:02 am
