Corner bath panel D...
[Closed] Corner bath panel DIY ?
7 Users
Ladies, Gents I need your help.....
Our house is fitted with a really old corner bath that I dont know the make or model off.
Our tenant has moved out and Ive just found out that they have damaged the bath panel beyond repair so I need to get one or make one...
The bath measures 153 cm x 95cm.
Any ideas oh how to make a bath panel for as little as possible?
Steve
Posted : 21/11/2016 8:54 am
I assume its curved? Flex MDF? Frame the bath with proper studding ie verticals and horizontals and simple screw the mdf to it? Needs to be well sealed from water tho
Posted : 21/11/2016 9:38 am
yes its a curved bath.
I had thought about mdf but Im slightly concerned about how well you can seal it.
Posted : 21/11/2016 9:39 am
Make a ladder frame up underneath and bend flexible ply round it?
Just make sure you get the sheet of ply that bends the right way
Posted : 21/11/2016 9:57 am
I would definitely go with ply over MDF but make sure it is well sealed with waterproof paint.You could look at getting some plastic cut specifically to the size and then putting that against the ladder frame.
Posted : 21/11/2016 10:21 am
If it's curved, I'd channel line it.
Posted : 21/11/2016 11:16 am
You're selling the house right, you've already exchanged haven't you (or did you back out in the end), just leave it for the buyers.
Posted : 21/11/2016 11:24 am
No it didn't sell. The buyers missed their own deadline despite being very pushy. Then they wouldn't agree to another date and then another so we took it off the market to tidy up and re let.
Posted : 21/11/2016 12:21 pm
For a little bit more cash but a lot more curb appeal, I'd do the curved MDF and put some mosaic tiles on.
It would be good to make the frame up so you can undo a couple of screws at each end, slit the silicone and slide the lot out to get at pipework when you need to though.
Posted : 21/11/2016 12:28 pm
What sort of thickness mdf would you use and how the heel do I make a frame for it to fit too?
Posted : 21/11/2016 1:06 pm
They sell special MDF that has ridges cut in so it curves or use 6mm Ply.
The frame just make up out of some rough cut 2 x 2 scrwed to the floor and the some uprights and supports under the bath.
Posted : 21/11/2016 1:16 pm
