Converting r80 spot...
[Closed] Converting r80 spotlights to fire rated low energy?
2 Users
Got 4 CFL r80 spots in the kitchen extension and the wind blows a gale through the fittings - it's a single story extension.
So the ideal outcome is 4 wide spots still, using low energy bulbs giving equally wide coverage, but with no air leakage. Afaict a fire rated fitting has to comply with air movement regs and is less 'drafty' ?
But can I find a wide angle low energy fire rated fitting?!
Halfway house is to fit fire hoods over existing fittings to try to cut the drafts a bit.
So, anybody had similar and figured it out?
Yawn what a boring question, sorry!
Posted : 14/08/2011 7:39 pm
The holes left by R80 fittings are usually too big to accept fire rated fittings.
The widest fire rated/sealed fittings are the ones with a tilting centre. A hole is still likely to only be around 85mm+-
Other option is to fit a converter fitting, they're not sealed but give you the option to fit LV/LE/GU10 etc.
Posted : 14/08/2011 7:51 pm
Hi, yeah I'd noticed this too, I would probably cut a ring of plasterboard and fix it in the original hole, skim over etc
But am I right in thinking an r80 fitting can't be had as a fire rated model? Can't find any anyway!
Posted : 14/08/2011 8:01 pm
No not actually fire rated, though some were one piece cans. Plus all the R type lamps will vanish over time.
Posted : 15/08/2011 10:32 am
