But perhaps more oval, or flatter in cross-section, rigid, with an easy opening top.. any ideas?
My new bag has two bottle pockets, and I could do with containers that are of similar size but not bottles.. and the typical tupperware type food ones are a bit too square and chunky.
I'd try and find some tupperware type food containers that aren't too square and chunky... Like a drink bottle but perhaps more oval, or flatter in cross-section, rigid, with an easy opening top.
Seriously? Are you really asking this??
Like this?
[url= http://www.decathlon.co.uk/bike-tool-box-750-ml-id_8324324.html ]http://www.decathlon.co.uk/bike-tool-box-750-ml-id_8324324.html[/url]
Not sure you're understanding.
I was asking if anyone's seen or bought anything similar, and if so where they got it from. Didn't think that was an unreasonable thing to be asking..?
EDIT ooh yes, PP, that looks pretty good ta - not oval, but should still fit.
Something like [url= https://www.amazon.co.uk/Lock-HPL931L-430ml-Round-Container/dp/B0017J7Y20/ref=sr_1_77?s=kitchen&ie=UTF8&qid=1462976573&sr=1-77&keywords=tupperware ]this?[/url]
Not sure there'll be flatter in cross section, as they are designed to go in bottle cages, but how about a tool bottle with a screw-top lid.
Like these:
[url= http://www.robertdyas.co.uk/breville-blend-active-bottle-600ml?istCompanyId=bf3344d9-83f5-4abd-b69a-da131f7567d1&istItemId=pqqmilxra&istBid=tztx&gclid=CJDk_-ec0swCFa0W0woduYsPgg ]Blend Active bottles?[/url]
Solid plastic, holds 600ml and narrower in the middle section.
maybe look at food flasks which will have have a bigger opening at the top.
Avex also make a travel mug where the lid screws on tightly and the drinky bit locks shut. Has a good wide opening at the top with no shoulder.
My Osprey Talon 6 waist pack with external bottles has flatter profile bottles, 750ml IIRC, they might be OK if you can fine someone who sells them individually
Platypus bottles?
The bottle cage containers will probably be best. The small merlin ones would be less likely to fall out than the taller ones.. Ta folks.
