Computer Help Pleas...
[Closed] Computer Help Please
7 Users
I'm having problems with scripts - keeping getting an error message on here, 'do I want to run scripts, yes/no?'
Can't sort it, tried download new IE, etc but not working - do I need to download JavaScript?
Posted : 01/01/2009 9:17 pm
Download & install the Firefox browser & do yourself a huge favour.
Posted : 01/01/2009 10:39 pm
wot he said^
Posted : 01/01/2009 10:40 pm
I have in 'programmes' Mozilla Firefox, is this it & how do I make it run instead of IE?
Posted : 01/01/2009 10:59 pm
Donít download IE8 itís a pile of poo ñ it uses most of your CPU and launch multiple processes that ground you Pc to a halt ñ apparently (according to an article I read) it only functions well on quad core process ñ some kind of MS conspiracy to make us buy new hardware ñ I now use firefox
Posted : 01/01/2009 11:41 pm
 devs
Download the latest java from [url] http://www.java.com/en/download/index.jsp [/url] and the latest flash from adobe.com.
Let us know if that cures it.
Posted : 02/01/2009 12:31 am
devs - done both but no good. When I go to google it says 'you must have JavaScript enabled to use this page'
How do I run Firefox?
Posted : 02/01/2009 8:37 am
Sounds like you have not given IE permission to run script for this site.
Posted : 02/01/2009 8:41 am
OK so how do I do that?
Posted : 02/01/2009 8:44 am
If you've got Firefox on your machine just launch it.
Assuming you're connected to the web it should work.
Posted : 02/01/2009 9:00 am
To be honest I'd just use firefox like others have said, it's not hard just launch it like you do any other programme.
Posted : 02/01/2009 9:01 am
I think the problem is BTYahoo! is set as default browser?
Posted : 02/01/2009 9:07 am
Can you launch Firefox?
Posted : 02/01/2009 9:14 am
Yes.
I've jst gone to the BTYahoo home page to update the browser so I'll see if that helps.
Posted : 02/01/2009 9:22 am
update which browser?
are you using FF or IE?
Posted : 02/01/2009 9:31 am
How do I choose which browser BTYahoo uses?
Posted : 02/01/2009 10:12 am
open FF go to tools>options>advanced>system defaults and tick the default browser.
you can also set your home page in tools>options>main and set your home page to whatever you want
Posted : 02/01/2009 11:30 am
In >advanced - only can 'reset' or 'restore advanced settings'.
Disable Script Debugging (Internet Explorer) is ticked - should it be?
Disable Script Debugging (Other) is ticked - should it be?
Posted : 02/01/2009 11:48 am
dickie - Member
In IE mine are both ticked, but I never use IE. Give FF a go 😉
Posted : 02/01/2009 11:51 am
I would if I could only get FF to be the default browser - Should I unistall internet explorer than its got no option?
Posted : 02/01/2009 12:00 pm
Make sure it's FF 3 you have installed.
Tools->options->Advanced-> select general tab the bottom tick the always check box.
Posted : 02/01/2009 12:26 pm
I have two options;
Tools>Internet Options>Advanced - no always check!
or
Tools>Browser Options>General>Always check to see if BTYahoo is the default browser.
Posted : 02/01/2009 12:43 pm
FFS Man! Run FF and follow the the bit above.
Posted : 02/01/2009 1:43 pm
sorted yet 🙄
Posted : 02/01/2009 4:15 pm
Someone probably told him to turn his PC back on and off again but he's not sure how to put it back on and can't ask on here. 😆
Posted : 02/01/2009 6:27 pm
Hey nice one Drac - the neighbour turned it back on for me!
Seem's Ok at the moment.
Thanks everyone.
Posted : 02/01/2009 6:37 pm
