Computer help neede...
[Closed] Computer help needed
8 Users
Should be getting a new laptop this afternoon, Question:
Can I connect my old laptop to my new laptop via USB to USB to transfer over programs/files etc???
Cheers in advance
Scott
Posted : 02/02/2010 10:59 am
no
Posted : 02/02/2010 11:00 am
I thought not, ok cheers for that. I have an external hard drive I can use but was trying to be a bit clever.
Posted : 02/02/2010 11:03 am
Have you got a X over utp cable or a couple of normal ones & a router or hub?
Posted : 02/02/2010 11:04 am
yes, but you need a special USB lead with A connectors both ends and a blob in the middle
Posted : 02/02/2010 11:06 am
Either make and image of old laptop HD and restore to new one, or just do a fresh install so you can leave behind all the crap you never use anyways.
You can do it with a network cable as long as it's a crossover cable, or you can do it via wifi I think.
Windows comes with a wizard to help you automatically with this though, and I am sure that it'll handle the setting up of wifi ad-hoc network to let you do this.
It's called Windows Easy Transfer and it works with a network, a special USB cable or a USB hard drive...
Posted : 02/02/2010 11:24 am
If its a new laptop then you dont even need a crossover cable - in all new Dells I have seen the NIC is auto sensing and does not need a specific crossover cable, a normal one will work fine. I imagine that all new laptops are the same.
Posted : 02/02/2010 11:54 am
or just stick both devices into the same router/hub using standard straight ethernet cables. (assumiing the router hasn't been set up to provide network isoalation)
Posted : 02/02/2010 12:06 pm
