Composite front doo...
[Closed] Composite front door question
Should a composite door be wood or aluminium inside? Any thoughts?
Posted : 01/04/2011 4:39 pm
 aP
Depends.
Could be steel.
Posted : 01/04/2011 4:43 pm
Ok. I'll re-phrase it Which type of composite door is best?
Posted : 01/04/2011 4:45 pm
 aP
Depends.
Is it a fire door, a security door, a ballistics door, in a school, an office building or a private residential home?
Posted : 01/04/2011 4:53 pm
Normal composite front doors are fiberglass moulded front and rear panels which are layered onto afew layers of ply then have a ali plate fitted around the external edge.
Posted : 01/04/2011 4:56 pm
 goog
£400 should get you a good one
Posted : 01/04/2011 4:57 pm
£400 will get you a bottom to mid range they are well above that especially the fire rated 1's
Posted : 01/04/2011 4:58 pm
Further details. The door I am looking for my front door, i.e. residential.
Posted : 01/04/2011 5:00 pm
Could have a proper composite door, aluminum external (RAL colour of your choice), pvc thermal break and proper hardwood (American Ash) on the inside. Pricey though.
Posted : 01/04/2011 5:02 pm
you just want a standard composite door then unless you live in a high crime area or fancy paying more for a fire rated.
Even with the added security in the panel and all the locks in the world a criminal can still smash your window...
Posted : 01/04/2011 5:03 pm
