cheap laptop for zw...
[Closed] cheap laptop for zwift
11 Users
Looking to get a cheap laptop for use with zwift mainly I know very little about them but looking at refurbished ones
will
http://www.cheaplaptopcompany.co.uk/all-laptops/refurbished-dell-e6220-windows7-4gb?sort=p.price&order=ASC
do the job? other suggestions more than welcome, cheaper the better as it will just sit in garage most of its life.
ta
Posted : 11/10/2018 3:48 pm
Apple tv is cheaper than that iirc and works well by all accounts
Posted : 11/10/2018 4:13 pm
For a PC  it's the graphics capability that is critical.
https://support.zwift.com/en_us/what-are-the-minimum-device-requirements-for-zwift--S1C6I6OB7
Posted : 11/10/2018 4:14 pm
Why not think about picking up an iPad too? Cheaper than probably a laptop that's capable of supporting it and you can connect it up to a TV easy enough for a bigger screen.
Posted : 11/10/2018 9:17 pm
Doesn't specify the processor generation which is MUCH more important than the iNumber bit these days a google suggests it's 5th gen dual core so not that sprightly but might scrape the lower end.
PITA them and sufferfest won't do android
Posted : 11/10/2018 9:24 pm
I use Apple 4K TV set up. Apparently it uses the same processor etc as Apples top of range lap top .. so it runs Zwift faultlessly.
easy set up to big TV too.
Posted : 11/10/2018 9:43 pm
https://en.wikipedia.org/wiki/Apple_A10X
Just the Ipads, the laptops run standard intel processors like half the laptops in the world
Posted : 11/10/2018 10:00 pm
Having struggled getting Zwift working well on a cheap PC I'm thinking of just getting an Apple TV this winter. According to Apple the 4K TV does use the A10X though Zwift will also work on the cheaper 4th gen A8 version.
Posted : 11/10/2018 10:04 pm
Last winter I just got a 2nd hand iPad mini2 £90 and a special cable to plug into the tv £10 worked perfect
Posted : 11/10/2018 10:47 pm
https://support.zwift.com/en_us/what-are-the-minimum-device-requirements-for-zwift--S1C6I6OB7It apparently works on an iphone 5 so no idea where they are pulling the minimum specs from!!
Posted : 11/10/2018 10:49 pm
Just get an Apple TV. They work perfectly and much better than even a decent laptop. I bought the 4K one for the turbo in the garage as I cba to mess around with a laptop. I believe the graphics may be slightly better on a top end laptop but if your doing proper intervals/training you won’t care.
Posted : 11/10/2018 10:51 pm
never used apple stuff before, if I get an second hand ipad will this have usb for the ant+ dongle and same question re apple tv, the laptop option would give us a second laptop for the kids for school work as well, also looking at a Lenovo x230 thinkpad
https://www.ebay.co.uk/itm/Lenovo-Thinkpad-X230-Laptop-i5-3rd-gen-8GB-RAM-Windows-10-Pro-MS-office/253917194622?hash=item3b1ea4e97e:g:~TIAAOSwbAJbmNF3:rk:8:pf:0
ta
Posted : 12/10/2018 10:04 am
 mos
Can you run 2 screens from an Apple TV with different things on?
When i'm doing the training sessions where it sets the wattage on a smart i find zwift to be a lot less immersive, so it helps to be watching something on youtube at the same time.
Posted : 12/10/2018 10:14 am
Just a thought could you use an iPad and Chromecast (or similar) to get Zwift on a big screen?
Posted : 12/10/2018 10:29 am
I ran zwift with no issue on a Surface 3. Intel Atom 1.6Ghz, 2GB ram integrated graphics. I don't get all these people saying you need monster pc`s with dedicated graphics etc.
Posted : 12/10/2018 11:35 am
never used apple stuff before, if I get an second hand ipad will this have usb for the ant+ dongle and same question re Apple TV
no, with apple stuff you connect to Zwift using bluetooth, which is by far the best way of doing it. You don't (can't?) use an ANT+ dongle. Obviously you need a (smart) trainer that connects by bluetooth not just ANT+!
Posted : 12/10/2018 12:42 pm
I ran zwift with no issue on a Surface 3. Intel Atom 1.6Ghz, 2GB ram integrated graphics. I don’t get all these people saying you need monster pc`s with dedicated graphics etc.
Probably talking about running it in 4k. The min spec requirements otherwise are pretty low, as you say.
sadly not!
You can use an Apple TV to mirror the iPad to a telly 😀
Posted : 12/10/2018 2:38 pm
