Car Battery questio...
[Closed] Car Battery question
I've got twin starter batteries in my van, in parallel. If one battery won't hold a charge, am I likely to have any charging problems- should I just remove the second battery and tape up the terminals, or is it ok to leave it there?
Posted : 19/02/2010 1:54 pm
Remove the dead battery, the reason it's not holding charge is because (most likely) it has developed a higher than normal self-discharge rate (internal shorting etc)- this will pull down your larger battery. If they're in parallel the only issue you may have is that your charger may now become a sledgehammer for cracking the nut of one battery, cooking it during charging if it's not a very intelligent one, rectify it fairly soon and you'll probably have no issues.
Posted : 19/02/2010 2:54 pm
thanks coffeeking.
Posted : 19/02/2010 3:21 pm
While it's out check its electrolyte levels, it could just be that it's dryed up (for some reason, usually not good reasons but worth knowing).
Posted : 19/02/2010 3:25 pm
