Car A/C - how much ...
[Closed] Car A/C - how much does yours affect mpg?
30 Users
Not sure if it's urban myth or not but have always been led to believe that car air conditioning when on will reduce miles per gallon. Has anyone on here actually measured it, what sore of reduction does it make to car fuel efficiency?
Posted : 27/06/2011 1:33 pm
Depends on the car - my other half used to have a Ford Ka and the air con used to really affect performance & economy.
I haven't really noticed a difference in economy with my 1.9 TDI Ibiza but that's a big, torquey engine in a small car.
It might be a couple of percent, but is within the tank to tank variation, I think.
Posted : 27/06/2011 1:39 pm
It used to be much more - compressors were on all the time. Nowadays they are a lot smarter and only run the compressor for a bit.
In the Prius and the Passat it's impossible to tell. The increase in economy due to hot weather far outweighs any decreased caused by AC because we always get better economy on the hottest days.
I suspect Ford of using crappy technology in their older cars because my Dad's 53 Fiesta used to make this huge wooshing noise with the aircon on at idle - sounded like a Ranger Rover or something - but no car I've had did that.
Posted : 27/06/2011 1:41 pm
I only use a/c on open roads (do 2-3 30 mile inter-town trips a week). No noticeable mpg hit. Bit I did notice that I can fairly rev the engine when stopped by using the a/c and demister.
Posted : 27/06/2011 1:42 pm
read somewhere that an aircon unit takes about 15 bhp so imagine your car with 15 bhp less and the effect on mpg.
mrs rocket has a Fiesta you can actually feel it 'ease off' on the m-way when the aircon starts up. Aircon/hills/headwind/passengers none of it makes any difference to the mighty Mondeo.
Posted : 27/06/2011 1:45 pm
It's not a myth. To run a compressor takes energy and the only source of energy a car has is the petrol or diesel. Any fuel used to run the AC is therefore not available to propel the car and therfore reduces the mpg.
Posted : 27/06/2011 1:46 pm
I remember reading that over about 45-50 mph* it's more fuel efficient to use the Air-Con than have your windows down.
* or summink like that.
In this weather I couldnt give a monkeys how much extra it used if my mpg halved and the AC kept the car cool I would be happy!
Posted : 27/06/2011 1:47 pm
Yeti - depends how hot it is.
If it's 32 degrees outside having the windows down isn't going to make you comfortable whatever happens 🙂
Posted : 27/06/2011 1:49 pm
I'm not sure it does. Certainly nowhere near as much as learning to drive economically, put it that way
I think it use to cost about 1-2 mpg on our diesel Vectra but I don't think it makes that much if any in our petrol Focus. That said, I rarely use it TBH. And when I do I tend to not leave it on all the time anyway.
Posted : 27/06/2011 1:50 pm
True.
And having them down at slow speeds does next to **** all.
Passat doesn't have an 'aircon' button, it has an 'economy' button instead. When this is selected it never uses the AC. When it is, it uses it judiciously to maintain the blower air temperature. Along with electric heaters to blow warm air when the car's cold 🙂
Posted : 27/06/2011 1:55 pm
My skoda has the same climate control system. I reckon using economy saves between 5% and 10%
Posted : 27/06/2011 2:02 pm
autoexpress did some tests of this a while back, simulated 30mph urban driving...
30.5mpg – Astra’s baseline fuel economy
30.4mpg – Two front windows a third open
30.3mpg – Roof bars and laden roofbox
30.2mpg – Two front windows totally open
29.7mpg – Four tyres down to 20psi
28.0mpg – Air-conditioning on
27.2mpg – Three large adult males in the back seat
24.1mpg – Roof bars and laden roofbox, plus three adults in the rear, a bike carrier with two adult bikes and air-con
Eco driving: The main facts
- Air-conditioning makes a big difference when driving at low speeds, but has very little impact on the motorway.
- Having the windows up or down makes very little difference.
- A modern aerodynamic roofbox barely impacts on fuel used.
- Slowing down on the motorway will boost fuel economy dramatically.
Read more: http://www.autoexpress.co.uk/news/autoexpressnews/229776/the_mpg_mythbusters.html
Posted : 27/06/2011 2:08 pm
A modern aerodynamic roofbox barely impacts on fuel used [b]around town[/b].
FTFY.
I'm fairly nerdy about fuel and have not noticed that, but then I'm not doing the same trips all the time in the same conditions so any effect is drowned out by statistical noise. It certainly has less effect than the weather. 10% would be 5mpg, that'd be noticeable even if I just switched it on whilst driving a flat piece of road.
Posted : 27/06/2011 2:17 pm
I've got a 2007 C220 Mercedes and the MPG is no different with A/C on or off.
Posted : 27/06/2011 2:40 pm
Only going around town, out a roof box on and do the test for the journeys most people use a roof box for (50-70mph) and the effect will be significant.
Posted : 27/06/2011 2:55 pm
My Smart diesel only has 45 hp to start with, I'm sure I'd notice if I suddenly lost 15 hp 😀
Posted : 27/06/2011 4:34 pm
Dunno, never use it. Ripped it out of my other car as it weighs too much.
Posted : 27/06/2011 4:42 pm
It does use fuel - it has to or you could run your fridge at home for free.
But driving when feeling all hot normally makes you drive worse (for economy) so being nice and cool and comfy might actually save you fuel by making you drive more relaxed and not mind taking 2 minutes longer by travelling a bit slower. Speed and changing speed is the biggest factor in MPG as drag, and thus power, is a square relationship to speed and braking is energy lost to heat (unless you drive a Prius).
Posted : 27/06/2011 4:46 pm
I think on Mythbusters they discovered that there's hardly any difference between running the AC and having the windows down.
Posted : 27/06/2011 4:49 pm
There's hardly any difference at all on a modern vehicle, the air con pumps are fairly high efficiency and only a small amount of power is required to do the task at hand (as a percentage of cruise power output) so I'd not expect much more than 1mpg difference on a relatively modern mid-sized car. It should be approximately the same fuel use on any vehicle (roughly the same air con requirements per car except maybe some really small cars) so the % may seem larger on super mini type vehicles (i.e. 2 ml extra per mile is a lot more % wise to a car that only uses 50 for motive power over one that uses 200).
Posted : 27/06/2011 5:00 pm
Negligible.
http://www.airconditioningforcars.co.uk/ACpage05.htm
Posted : 27/06/2011 5:03 pm
Awesome page "I've found no useful figures apart from those in trucks (different kettle of fish)), however here's my useless figures which have no useful info about AC usage" 🙄 (And from a source with a vested interest in increased AC use!)
Posted : 27/06/2011 5:09 pm
dunno, the AC isn't working at the moment*. it's a sweatbox on wheels.
* booked in for Saturday, earliest I could get somewhere local
Posted : 27/06/2011 6:33 pm
I_Ache - Member
In this weather I use it to keep the windows de misted, 12C and pissing of rain all day. 😥
Posted : 27/06/2011 6:41 pm
Not a very good comparison though because they had a huge truck with most likely a crude A/C compressor and they compared it to driving with all the windows fully open.
Posted : 27/06/2011 6:47 pm
But it doesn't use FUEL. it uses electricity assuming that a "smart" system uses excess electricity after all systems are charged then no noticeable effect.
Posted : 27/06/2011 7:56 pm
Yes it does! Where else does it get the energy from? (Unless its a hybrid and using regenerative braking)
On a similar note, why do cars with air conditioning have rubbish demisters iff the air-con isn't on?
I know with the air-con they're good as they dry the air, but turn it off and you're left with a misty screen. But in an older car with no air-con, they clear pretty quickly.
How so?
Posted : 27/06/2011 8:04 pm
The compressor is driven by the crank.
Posted : 27/06/2011 8:05 pm
never seen an electric aircon compressor as yet. All I have seen are belt driven off the main crank as already said - which is the most efficient method anyhow ( rotation crank > rotation compressor ) as opposed to electic which would be rotation crank > alternator > compressor motor - each with their efficiency losses )
As for the demisters thing ....
As the warm air from outside has moisture in it, when it passes over the very cold aircon evaporator that moisture in the air condenses on the evaporator matrix and fins. So not only has the system taken the heat out of the air, but also the moisture ( which is wou get all the drips under the car ) So the air that gets into the cabin ( hot or cold ) is drier than the air inside the cabin, and so it soaks up moisture in the cabin ( and thus demists )
It doesn't work with the AC off cause the moisture isn't taken out of the air before entering the cabin.
Posted : 27/06/2011 8:52 pm
 krag
Can't say it makes a big difference to MPG for me but then my car is pretty thirsty anyway (280bhp Subaru Legacy). There's a noticeable (but small) loss of power when you press/de-press the aircon button though...
Posted : 27/06/2011 10:50 pm
Our Galaxy has climate control & the advice from some of the mechanics on the Galaxy onwers club is to leave it on "Auto" at between 21 & 24deg. The reason being the extra cost of the fuel is nothing compared to the cost of replacing the AC components that can fail if its not used regularly. And 36-40mpg isnt bad for a big car.
Posted : 27/06/2011 11:00 pm
Best thing my RS4 has is a solar a/c thingy that keeps the a/c going in the summer when I am not in the car, powered off the sunroof. Come back to a pleasantly cool car instead of blistering hot leather.
Posted : 27/06/2011 11:34 pm
 DrP
A very good idea! Wonder if it can be retrofitted...
Do you have to 'turn it on', or does it do it simply when it's hot enough?
DrP
Posted : 28/06/2011 6:31 am
...and the electricity comes from where exactly? Even if you have regerative braking all the energy that runs everything in a car ultimately comes from the fuel.
Posted : 28/06/2011 7:13 am
Living in Scotland I can say my mpg is very, very, very rarely affected by a/c!
Posted : 28/06/2011 7:55 am
Priuses have them.
I'd be surprised if it powered the actual aircon rather than just the blower. The Prius has that as an option - whole roof covered in solar and it still only powers the fan, even though the compressor is electric as mentioned above.
Posted : 28/06/2011 8:27 am
Do people actually turn the aircon on and off? I just set mine to whatever temperature I want (usually 18 degrees celcius) and forget about it
Posted : 28/06/2011 8:52 am
randomjeremy - Member
That'll be climate control & not air-con. I guess climate control is just an 'intelligent' air-con, though.
If I had 'just' air-con I probably wouldn't have it on all the time - only when needed.
In my car if you stick the climate control on 'econ' which turns the air-con bit off and it starts to get toasty, the system just ramps the fans up to try and get some flow through the cabin & match the ambient to the desired temp on the display. This gets a bit blowy/noisy/annoying so it's better to just leave it on auto & let it do it's thing.
Posted : 28/06/2011 9:01 am
I wonder how the RS4 thing works?
Could be some peltiers and a fan powered by solar/battery. Not as efficient as a compressor system but quite small and scalable.
Personally I would rather have electric compressors along with electric water pump and PAS. Yes having to generate more electricity seems to add more inefficiency into the system but electric means you only need them on when needed, you can have them running with the engine off and you can boost them independent of engine speed. It also does away with parasitic serpentine belts and tensioners and idlers and means you can put things in accessible places and free up room around the cambelt for access. As well as not taking out your cambelt when something fails (eg water pump).
The new peugeot/bmw turbo charged petrol engines use electric water pumps so the pump does not run when the engine is warming up and can continue pumping water when the engine is turned off.
Another benefit of electric items is they can be shut down easier when accelerating so instead of needing a 120hp engine you can get away with a 110hp engine for the same acceleration response. Small savings which are all helping push up MPG figures.
You can also reduce the engine electricity generation load by extracting more energy during braking which helps reduce brake wear (slightly) and utilises waste energy.
Some mechanical aircon systems do this already (the old peugeot 306 one does) in that the magnetic clutch releases during hard acceleration to free up engine power.
Posted : 28/06/2011 9:09 am
Modern ones do that for you anyway - even if they aren't climate control.
Posted : 28/06/2011 9:10 am
So
A) When I haul around a full tank of fuel its costing me money
and
B) Even when she is sat in the passengers seat ... the wife is costing me money !!!
Posted : 28/06/2011 10:51 am
molgrips - Member
Eh? I don't get this.
I mean with normal air-con I'd only turn it on when it got hot & stuffy inside the car or I wanted to clear the screen.
If it was a comfortable temp/cold outside/a bit warm/I wanted to drive with the windows open/I was just popping to the shops then i wouldn't turn the air-con on. So it would be off.
I don't mean that the air-con will regulate somehow, I just mean I wouldn't actually turn it on.
Like her indoors' 58 plate Pug 308. If you turn the air-con off, it is off. If it is on, it is on
It doesn't turn on when needed, as it doesn't know when 'needed' is. Whereas the climate control 'knows' that it is constantly trying to achieve 20 deg. C. or whatever it's set-point is.
Posted : 28/06/2011 11:10 am
There can be benefits of having it always keeping a check on temps as keeping the temp in check requires much less instant power than trying to cool from a very high temp. You can then potentially get away with a much smaller system which can be better optimised. It also ensures the system is kept in good working order as seals need to be lubricated which happens when the gas is flowing.
I do agree that you should be able to turn it off though. Just don't keep turning it on and off thinking you are saving power. If you want it on leave it on and keep it ticking over. If you are doing a short trip and/or have windows down etc then leave it off.
Posted : 28/06/2011 11:14 am
What I meant was that I think there is some kind of ballast in the system. So the compressor comes on, chills the coolant, then goes off again - like a home fridge. You won't notice the actual switch coming on or off, or the air temperature changing - to you, it's ON all the time but the compressor is not actually running the entire time.
This is only a supposition tho based on a few bits of reading on forums and such.
The new Prius has no belts at all, not even a cambelt - for the reasons you describe. Mine only has one on the water pump. You've got as much electrical power as you need at any given time, so you might as well take advantage of it.
Even really old cars have this - my crappy old 94 Passat had, if you had one with AC which I didn't. It was built into the injector pump.
Posted : 28/06/2011 12:13 pm
