I'm refitting a bathroom, and have been able to re route water from the updated copper piping. This leaves me with a redundant lead cold feed that comes up from beneath the concrete I believe the other end is somewhere under the kitchen which at this stage I don't want to rip out...
What is the best way to cap it off? I've been looking at leadlocs and then use a screw cap, can't work out the right size I should be using, and they are reasonably expensive
Any other options? I was thinking about crushing and heating the end but I reckon that will end a right mess.
We bent one over and crushed it.
(It was an outside pipe though and we had just sold the house)
Proper capping looked complicated for the reasons you have said
They uses to just hammer em flat then a bit of lead solder.
Do not do what an Asian gentleman dis back in our piling days. He didn't like the flattened lead pipe that was sticking up out of the floor after the refurb. So he took it upon himself to bend back and forwards to remove, he was warned not to as it could be live. And there she blows all over nice new plastered walls....
[quote=FunkyDunc ]We bent one over and crushed it.
we had one like that in our shed when we moved here. a couple of years later it started dripping occassionaly, then more frequently. couldnt isolate it either, think it may even come from next door.
now we have a leadloc terminated with a tap so I can draw water for the garden...
What is that leadloc you used there?
The ones I've been looking at online are brass and seem to work by a compression type claw. Looks a fairly old design.
Potentially I could re-reroute it to feed the toilet cistern and use the copper fed for the basin. I will definitely have to cut it back though as it current feeds a cistern above head height that is knackered and leaking
EDIT - is it this?
https://www.pipestock.com/philmac/universal-transition/joiner
Cheaper and looks like it might be easier to use as it covers a range of diameters
The pipe does have what looks like an old shut off valve but the tap head is long gone and I can't turn it with molgrips.
think it was one of these.
https://www.plumbcenter.co.uk/product/philmac-universal-transition-coupler-21-27-x-15-21mm/
been in 18 months now and absolutely fine.
thanks will give that a try. bonus there is a plumbbase about a mile from work too
You're probably going down the best route of re-using the lead line rather than capping off, as the length of capped lead pipe would be substantial and it would then become a dead leg of stagnant water over time, potentially contaminating the current cold water feed.
