Canon DSLR: Err99
[Closed] Canon DSLR: Err99
Had it in the past with an old lens, now getting it about 60+% of the time.
EOS 350D body, Canon EF lenses.
When you fire the shutter release it sounds like the shutter doesnt fully open and close and you get a soft sound instead of a "kerlut"
Then Err99 in the screen and on/off required.
Have tried a couple of various forum solutions: fresh battery, rubber to the lens contacts, changed the lens. Happens in all modes too.
Any ideas before I reluctantly take it down the LCS?
Posted : 11/06/2012 8:04 pm
 deft
It's a tricky one: www.lensrentals.com/blog/2008/12/canons-error-99-the-man-the-myth
Formatting the card (from the camera menu) is usually my first step
Posted : 11/06/2012 8:09 pm
Error 99 is a general error if I remember right. I.e. unknown...
I have a 350d that does it when the flash doesn't pop up properly.
Posted : 11/06/2012 8:10 pm
Ooops, double post
Try cleaning the contacts on the lens ring and the camera body - it's sometimes the case that the two aren't talking to each other if they're a bit minging.
EDIT: Sorry, just read the OP properly. In that case, as above, fresh card and format in camera? You do format your cards in the camera yes?
Posted : 11/06/2012 8:11 pm
cheers deft, working through the article. Telling.
This seems relevant, as mine is a 300D (sorry typo above) which is similar to the Rebel I think? And Im using the 2.8 20-35mm ATM
Several lenses with newer IS, including the 70-300mm f/4-5.6 IS (2005), EF-S 17-55mm f/2.8 IS (2006), and 70-200mm f/4L IS (2006) became very popular with photographers shooting EF-S mount cameras. We know that malfunctions in some of these lenses, most commonly reported with the 17-55 f/2.8 IS, cause Err99 (and not Err01) on EF-S mount cameras. Cleaning the electronic contacts on the camera and lens will often fix, or at least improve the problem. There are a few reports that the problem is more common with original Digital Rebel
Posted : 11/06/2012 8:18 pm
me that only *** works! Legend!
Posted : 11/06/2012 8:20 pm
Same thing.
"Rebel" is equivalent to "EOS". The "original Rebel" was the EOS 300D.
Posted : 11/06/2012 8:26 pm
 deft
Good stuff ๐Ÿ™‚ I now make it a habit to format my cards pretty regularly in the camera itself (and carry a spare!)
Posted : 11/06/2012 8:51 pm
