Can you name this pulley/hanger thing
I shall name it Adrian.
I would try a chandlers, might be a block off a boat? Can you give us an idea of size?
if not a boat chandler, then maybe a Theatrical Chandler like [url= http://www.flints.co.uk/acatalog/Pulleys.html ]Flints[/url]
Something to do with curtains? Try a DIY store
that'd be my call too, but the screw fixing is a bit odd.
Not fancy sticking it back together?
You should love it, hug, it, and hold it to your chest and call it George... 😆
It's a pulley, not a bunny.
It is only very small and cheaply made...the one in pic is part of a DIY Gopro zipline setup. It's the screw fixing that's got me. I searched through a few websites but can't find anything similar. 😕
It's the screw fixing that's got me[s] thats why you might find something is a theatrical chandlers as stuff is generally screwed to the back of wooden scenery
Never mind.
I just clicked in time tinribz, looks about right to me, close enough anyway.
A small sailing pulley would work, and you can get various, some that screw on (although they can be like that, or through the block etc) or that you can add a small shackle or fitting to.
Look for 'Barton' blocks - you would want size 0 for small stuff like that.
http://www.bartonmarine.com/products-size-0-blocks.asp
[img]
[/img]
Thanks Matt, those are too big though. The fact that the outer frame on them doesn't enclose the wheel means I can't cut a slot for the line either (I'd rather be able to hook it on instead of having it on the line whilst setting it up).
probably not small enough, but searched under plate fit pulley:
http://www.ebay.co.uk/itm/190723453137
