Can you jump start ...
[Closed] Can you jump start a mower?
6 Users
I've gone and left the keys in my mower, a ride on mountfield and its battery is flat. Won't turn over, anyone know if I can jump start using my car and jump leads ? Don't want to damage anything.
Posted : 12/08/2017 10:52 am
 JAG
If it's a 12v system in the lawnmower and car then it should be fine 🙂
Posted : 12/08/2017 10:58 am
yes as long as the voltage is the same then you should have no issues
Posted : 12/08/2017 11:02 am
12v so I'll give it a go. Just like a car in that once started I just keep it running for a while to get it fully charged?
Thanks
Posted : 12/08/2017 11:03 am
Have a read of this first
http://singletrackworld.com/forum/topic/how-can-a-bigger-battery-correct-voltage-damage-components
(Not a mower or auto electrician.)
Posted : 12/08/2017 11:12 am
If the battery is fully discharged, it can refuse to take a recharge. Mine's done that a few times and I've had to replace it. I now keep it on an Optimate like the motorboiks.
Posted : 12/08/2017 11:14 am
Now confused with my limited electrical knowledge..
Would you try it ? mower has a 12v 18Ah 200A battery?
Posted : 12/08/2017 11:33 am
I would (did), car to mower. The earth didn't stop rotating and I wasn't frazzled to a crisp but YMMV... 😉
I was just recording that even after I started mine, the battery was knackered so running it for a bit longer was pointless as it wouldn't take a charge. Again, YMMV.
Posted : 12/08/2017 11:52 am
Car has a 12v L2 400/640A battery
Posted : 12/08/2017 11:56 am
Found this online.
Sound advice ?
If your mower uses a 12-volt battery, use the jumper cables as you would when starting another car. Hook the positive cable to the positive terminal of the car battery. Then connect the other end of that cable to the positive terminal of the mower battery.
Then connect the negative cable to the car battery's negative terminal, and the other end to the frame of the mower. They come off in exactly the opposite order.
It then says to not start the car, just connecting as above should be enough ?
Posted : 12/08/2017 12:06 pm
Yes, as long as you don't flatten the car battery trying to start the mower.
Posted : 12/08/2017 12:45 pm
It worked!
Thanks all. I darent stop now.
Posted : 12/08/2017 1:27 pm
Starting and stopping now too. Might get the mowing done in time for more trail fettling now... whoo hoo
Posted : 12/08/2017 1:52 pm
Don't know where you are but about 50 mins ago, there was, a minor anomaly in the fabric of space/time. Felt like the earth juddered slightly on its axis. Was that you starting your mower? 🙂
Posted : 12/08/2017 2:16 pm
That's me. North Hampshire is the new magnetic pole.
Posted : 12/08/2017 2:20 pm
