Managed to run over the cable with the mower (Rotak 37) yesterday and can't yet find a replacement. I'm sure one exists - if so, it's one of those that just needs wiring in. If not, or if it's silly money, then surely I can just use electrical tape on each of the enclosed wires and then proof with gaffa tape etc?
Or is this dangerous?
Be fine as long as it doesn't rain (and probably fine then, too), and make sure you don't pull on it too hard.
Give it a go and find out?
Can you? Yes.
Should you? No.
Would I? Yes.
Coolio - good enough me for. Ta.
Sounds dodgy 🙂
But the Rotak mowers are great aren't they 🙂
</shedtalk>
Should be fine. Got a few cables that are patched together with tape.
IMO no point buying a new one unless the current one doesnt work. Electrical tape does fine.
I've done it, it was fine.
Absolutely (in the mower-scheme of things that is) - takes me half the time to do our lawn these days.
Of course instead of botching a connection with electrical tape you could stretch to the princely sum of £3.29 and use one of these which are [url= http://tinyurl.com/2wkssjl ]less likely to kill you.[/url]
You can fix [i]anything[/i] with electrical tape. Could probably do heart surgery with it.
what DrT said. The only problem with those connectors is they come apart quite easily if you pull on the cable. Maybe try and find one that clips together more robustly.
And make sure you have the female end on the lead and the male end on the mower. Not like the bodge done at a place I used to work at when similar happened. The numpty technician that extended the forklift charging cable had the male end on the mains, so he had the pins live when it was plugged in. Potentially shocking experience if you handle them.
I thought thats why they [i]called[/i] it electrical tape.
Electrical tape for electricity, duck tape for ducks 🙂
Seriously tho, I'd use it today, and probably next time, but a more reliable connection would be on my to do list.
