I've been quoted £4k to fit a £1500 Acr neo wood stove.
But more than I expected, was hoping for around the £3k mark.
So can I fit this myself?
Will be going in a single storey extension, nearest window over 5m away, no existing fireplace or chimney so will need a double insulated flue I presume.
Still needs to go above the roof line of the house unless it's over 2.3m away.
Our house had one in the conservatory put in by a previous owner that's had to be ripped out and bricked up.
So long as you understand the risks
https://www.theguardian.com/world/2017/jan/30/six-teenagers-found-dead-after-garden-party-in-germany
I have fitted a couple on building notices, however i believe it differs council to council. I usually use the selkirk flue installers guide, if i am using flue pipe. Without seeing the job 4k sounds plausible, 2k for stove, and flue. then 2k for scaffold?, labour.
best price from a couple of quotes or the first one you've got?
You can but if you use a HETAS fitter you dont need to involve building reg inspectors which is worth a fair bit in my book!
The extension will likely need a Building regs. application, so your building control body can sign the installation off as part of the application. Just ask them for advice/requirements in advance of fitting it.
read Wzzzz's website.
It's really rather good.
It's all you'll need to make your decision and then to fit the stove, if you decide to DIY.
If you are new build... you've may well have less to comply with ??
Resale consequences? I wouldn't buy a house with a self-fitted stove.
*complete exaggeration but you know what I mean.
£4k for what? *JUST* the installation? Or does this include any parts?
I just paid £2250 inc VAT for all this...
Parkray Aspect 4 woodburner
9m 316 grade solid fuel flue liner
Stainless steel suspension cowl, Stainless steel flue pipe adapter, Vitreous enamelled
flue pipe, Steel register plate and fixings
Remove fireplace, remove brick work to expose builders opening. Make good structurally and making good plastering around opening
Natural Limestone flagged hearth (Charcoal Grey)
Heatproof fireboard for stove opening
Gas to cap (By Gas Safe Registered Installer)
Building materials (lintel, cement, plaster, adhesives, fixings and spays)
CO detector
I was quoted £1k + hearth (could be 12mm glass) to supply and fit a twinwall flue in a single storey building (vaulted ceiling) by two different people - I had the stove already.
Your £4k sounds a lot.
None, just do it under a buiding control notice and get it all signed off.
I had a number of quotes for mine ranging from £2,800 to £4,200
The labour ranged from 400 to 950 and the flue ranged from 900 to 1750.
Price up the parts online and allow £200 per day for labour and overheads and you should have a reasonable price. Finding someone to do it for that might be the challenge but they are our there
OP - if you are in Bristol area I have a mate (HETAS installer) who is a top bloke who'd quote and/or advise you. Get it done properly, not just for safety but for efficiency.
I've just paid £2095 for an install.
Stove + flue pipe = £650
Knock out of fireplace = £200
Installation inc. Liner, stone hearth, steel register plate, fireproof boards, chimney pot & bird cowl etc = the rest.
How much is a double lined steel flue?
If you can wait a bit, you'll probably get a cheaper quote during the summer.
I fit stoves. I'm by myself so don't need to worry about finding work for employees. I see other local companies pricing stuff silly cheap in the summer when it's quieter. They need to pay wages every week so tend to cut prices to the bone to keep work coming in.
Me, I'm happy to take a couple of months out to do other stuff and let them slug it out. 🙂
Sorry, having a fit of giggles; I read it as "can I fit in my own log burner?". My dyslexia kicking in big Time!
Johnson 316 grade flue is for wood I believe not coal if you were going to burn that?
Loads of variables in the limited info you give, does it include the £1.5k stove? Does it include a flexi flue? how long, what type (flexi flue)? scaffold required? what work are they doing to the fireplace? new hearth stone? etc etc.
My totally notional fag packet figures to fit their quote
stove £1500
scaffold up side of house £400
fitting works and materials £300
twin wall flue £500
hearth stone £300
fireplace work ( fit hearth stone, plastering, making good, whatever etc) £750
fit stove and sign off £350
=£4000
I meant twin wall flue rather than flexi flue 🙂
I would have no qualms about diying it - just follow the relevant regs or do the labouring bits yourself and just pay the fitter to complete / check and sign it off.
Gave my mate a hand to do his, single storey and all was easy enough to do. Then signed off by building control. Saved a lot of money.
B.A.Nana - not sure about your prices, there is no fireplace! 🙂
There was an interesting article in the New Scientist recently about the impact on pollution and health from wood burning stoves. It's worth reading.
It's been done to death on here already.....
isn't that the abstract for the article?
If the £4k includes VAT, that's nearly £700 already.
my father in law is a sweep so i had a bit of a head start, but yes i have done all of ours. you can them get them certificated by your local council if you want, i never have.
ok, except one stove... for this i needed a hetas certificate, we needed a flue installing, and my father in law had recently had a heart attack so i paid a very large local compant over a grand for the job.
it was the biggest bodge you have ever seen with huge breaches of both the appliances installation guidelines, legislation and utter common sense. fortunatly i knew a bit about it and spotted the bodges, some of which could/would have caused a fire in the roof and i'm really not kidding.
so yes tiy can do it but you do need to know what you are doing, or you can pay heaps but you may get a worst job that you could do in the first place.
