Calling motorcyclis...
[Closed] Calling motorcyclist cheapskates: grip glue or hairspray?
14 Users
Need to replace the shagged-out grips on my scooter. Bought the grips. Do I really need "grip glue" or will hairspray work just fine, same as with bicycles? If it makes a difference, I am in a warmer climate...
Posted : 09/02/2012 2:09 pm
I use ODI lock-ons
Posted : 09/02/2012 2:11 pm
Grip glue holds grips on. Hairspray is for hair.
Posted : 09/02/2012 2:13 pm
Hair spray works fine
Posted : 09/02/2012 2:14 pm
Where are you konabunny and are there any jobs going?
I'll buy you some grip glue and bring it with me.
Posted : 09/02/2012 2:17 pm
Australia; maybe - check the Skilled Occupation List: http://www.immi.gov.au/skilled/sol/
Posted : 09/02/2012 2:28 pm
A little squirt of spray paint works every time for me.
Doesnt matter what colour just be careful of over spray.
Posted : 09/02/2012 6:13 pm
Aerosol spray paint here.
You can use clear lacquer so overspray isn't a problem.
Just degrease the bars properly, spray the bars and inside the grips, bang 'em on and you are sorted.
Posted : 09/02/2012 6:19 pm
Hairspray always works a treat without them coming lose again
Posted : 09/02/2012 7:32 pm
yep ive used hairspray, ive also heard a few drops of petrol will do the job just as well,
Posted : 09/02/2012 7:44 pm
Wd40 and lock wire
Never had a set come loose yet !
Wd40 allows them to slide on but then makes the rubber tacky too
Once the solvent evaporates they stick really well
Lock wire is really just to pull a tight seal against water ingress, as they can come loose without it
HTH
Dom
Posted : 09/02/2012 10:49 pm
wickes general glue, used it for the past 10 year on motocross bikes without issue, it seems to be identical to renthal grip glue to me.
Posted : 09/02/2012 11:25 pm
Wrap electrical tape round the bars, wash out the grips with petrol and put them on quickly.
Iain
Posted : 09/02/2012 11:42 pm
I've always used WD40 to put my mountain bike grips on. Works every time. No glue ever needed.
Posted : 09/02/2012 11:44 pm
Thank you all.
Posted : 10/02/2012 12:05 am
If i cant put them on by hand i use a pump.
Chemicals cause problems. Paint flakes and is probably the silliest idea ever to be put in a big mag (mbuk 5 years ago?)glue is good for heated grips on motorbikes (hence getting a tube WITH the grips)and electrical tape goes into a soggy mush after a year or two. I wish folk would quit doing this.. its a nightmare to remove off their bikes!
Posted : 10/02/2012 12:55 am
Moose/ODI do motorcycle grips.
Posted : 10/02/2012 12:58 am
Too late (for this vehicle, at least) with the ODI suggestions (but maybe next time once I sell it) but thank you anyway.
How would you use a pump? I don't understand.
Posted : 10/02/2012 5:50 am
It works best with an old fashion pump and closed end grips (with the wee hole in the rubber) You place the pump with no flexi connector against the hole,get someone to put their hand over the open end of the bars on the other side.. and pump it on.
Posted : 17/02/2012 9:43 pm
