Boundry wall advice...
[Closed] Boundry wall advice required,before it falls down.
[#1080337]
I own a property in a large purpose built block of appartments, at the rear is a wall about 50 foot long and about 10 foot high,going past 2 other properties.
Problem is the wall in question is probably over a hundred years old,and is buckleing badly in one place,the property that is on the other side of the wall has its garden to near the top of the wall and is on a higher level,how do we find out who is responsible for the wall and who pays for it to be taken down,piled and rebuilt,there are access problems getting to it,low headroom and the neighbours vegetable patch.
Posted : 27/11/2009 6:34 pm
if you've got a leasehold property in your block then it won't be you, or at least not directly. do the management company/freeholders know about it?
Posted : 27/11/2009 6:40 pm
I am one of the directors of the management committee.
Posted : 27/11/2009 6:42 pm
ah right 😀
well as far as i understand, if it's directly on the boundary then it's a 50/50 split, with each party responsible for their own half. so if it's urgent then i would get it done then invoice said neighbour for the costs of the wall and whatever extras for the access, ideally with their go-ahead.
i am literally no expert, though.
Posted : 27/11/2009 6:46 pm
The neighbours may not realise they have a problem yet.
Posted : 27/11/2009 6:53 pm
this is a nice chat we're having, isn't it? 🙂
this may sound patronising, but if you know there's a problem then shouldn't you, as one of the directors, tell them?
either way, if it's an emergency then you would be within your rights to just get it sorted and invoice them.
Posted : 27/11/2009 6:59 pm
you will need to check the deeds of the freehold to see if they specify who is responsible, if yours don't say then you'll need to see the neighbouring ones, easy if the properties are registered potentially tricky if not.
Posted : 27/11/2009 9:48 pm
check deeds as said. there should be a 'T' mark indicating who owns/is responsble for it
my understanding is that if it is not stated on the deeds it will probably belong to the property that is being "retained" (they are the ones benefitting from the wall)although this general
however in reality it may be easier, quicker etc to accept a 50:50 cost/responsibility split
boundary ownerships are notoriously difficult to establish if they are not indicated on the deeds
see a property lawyer
Posted : 27/11/2009 9:53 pm
