In the loft room we have a bt home hub hard wired in and get a good 38mps speed. We stream wifi to the tv in the downstairs room to watch netflix etc but only get about 15mps speed.
Bought a Netgear booster which we've plugged into a downstairs socket but it doesn't seem to improve it much if at all.
Any recommendations on what could help? (The router needs to be in the top room due to being the office). Thanks!
Powerline adapter with built in wifi at one end.
Got a set of these doing nothing, that you can have for £35 posted if they'd help?
http://www.shop.bt.com/products/bt-broadband-extender-flex-500-kit-075597-8W3V.html
What's the Wi-Fi speed in the loft room? I've got a similar issue with the poxy Sky router, its Wi-Fi performance is about half the speed of the broadband connection.
I'd have thought that would be ample for Netflix. What's the problem?
That would seem the obvious choice, aye.
I just bought [url= http://www.amazon.co.uk/TP-LINK-TL-WA860RE-Universal-Integrated-Pass-Through/dp/B00M0KILOA/ref=sr_1_1?ie=UTF8&qid=1458666673&sr=8-1&keywords=tp+link+wa860re ]this[/url] yesterday (though for £15 mind) as the corner of my son's room is a wifi dead spot.
Will see how well it works as was delivered this afternoon....
Might help you??
DrP
Thanks. We have this on a downstairs socket: http://www.netgear.com/home/products/networking/wifi-range-extenders/EX3700.aspx
but isn't great when i do a speed test. Netflix is generally ok, its the firestick that buffers now and then.
If the router is in the loft it may be better to plug the extender into a socket on the first floor so that it is nearer half way between the devices and the router.
It probably won't help much though as a wifi range extender has to receive and retransmit each packet and this can half the connection speed even when it is near both ends.
Cat5e cable @ 25p per metre and two sockets @ £2 each, only reliable way IME.
Typo surely you meant Wife?
Agreed. Every time, I think of this classic: http://singletrackworld.com/forum/topic/improving-wife-signal-in-house
+1
Important point this, much better with some CAT5 or Homeplugs physically connected to the router as the source if you can, then plug in a wifi access point.
WiFi will probably be split between the connected devices. Wired works best.
Indeed Mr bear
I had my ears syringed,it really boosted my WiFe signal. 🙂
Well, the device I mentioned above arrived..and all I can say is it does what it says on the box!
Plug in near router, press WPS button until lights flash correctly, then plugged into the socket at the front of my son's room.
Seems to work perfectly, now, and I even get WIFI all teh way to the front of the front garden.
Dead simple solution that did exactly what I, and probably you, need....
DrP
