Boost my confidence...
[Closed] Boost my confidence please...
14 Users
Never done tubeless before but about to ride (this weekend) 2010 (non tubeless ready) Nobby Nics mounted on Sun Ringle tubeless rims (licenced Stans design) tubeless.
It'll be fine, won't it? 😯
Posted : 25/01/2012 5:37 pm
Have you been working out?
Posted : 25/01/2012 5:42 pm
UR AWSUM!
Posted : 25/01/2012 5:43 pm
You are a intelligent and handsome chap with enormous charisma and enough wit and charm to get you into any girls knickers.
...did that do the job? 😉
I knew I could rely on the STW forum....
Posted : 25/01/2012 5:44 pm
My personal theme song... you can borrow it...
Posted : 25/01/2012 5:49 pm
Any confidence boosting (or otherwise)with regard to the OP availble?
Thanks in anticipation... 😕
Posted : 26/01/2012 10:26 am
[i]It'll be fine, won't it?[/i]
probably.
Do work outside, though, just in case;
[edit] ignore caption...
Posted : 26/01/2012 10:31 am
it'll be fine unless you're planning on riding over curbs, pebbles and other such hazards.
remember your fullface, body armour and flinstones plasters.
it could be a kids face next time.
Posted : 26/01/2012 10:33 am
I use NN on Stan's. I use non-UST and seal them up with the milk - watch the vids on notubes site - it a right faff but very satisfying. I have left these tyres for weeks without going flat, but do need a bit of air.
Never had a puncture since going tubeless, but have burped with instant deflation (I run low pressures).
Relax, it will be fine. (but carry 2 spare tubes with you, just in case....)
Posted : 26/01/2012 10:48 am
Nope, you are doomed, just for the original post 😀
Posted : 26/01/2012 10:49 am
Boost your confidence by taking three spare inner tubes along on your ride.
Posted : 26/01/2012 10:50 am
sugdenr - Member
That exactly what I've done - wheels/tyres have been in the shed inflated with no issues since Christmas. I'll be running at 30psi though.
Just worried about the instant deflation on the way down a rocky welsh descent...
Posted : 26/01/2012 11:05 am
Stans and normal tyres for the last 4 years here - I've burped tyres a couple of times, but never more than half deflation; pumped back up fine.
Rapid deflation on rocky descents for me is a lot less likely now because I don't snakebite any more.
Dave
Posted : 26/01/2012 11:08 am
Posted : 26/01/2012 11:11 am
I gave up on tubeless after a ripped sidewall and two complete burps. No point if you have to carry spare tubes everywhere and worry all the time. Must admit it felt nice though.
Posted : 26/01/2012 11:53 am
 MSP
If your tyres are burping you are running too low a pressure.
Posted : 26/01/2012 11:57 am
MSP 30psi should be OK though on a tubless rim? (Stan says max 40psi anyhow...)
Posted : 26/01/2012 12:16 pm
If it's holding air, seated properly and has sealant, then you will be fine unless running silly pressures.
Posted : 26/01/2012 12:18 pm
not sure what ripped sidewall has to do with tubeless
30 is fine.
My problem is I havent recalibrated from motorbike trials, rear sometimes 4-6psi on technical rocky assents.
Afan this weekend is it?
Posted : 26/01/2012 12:19 pm
