Are there any utilities that enable the entire backup of the whole of iTunes to include everything. Essentially a mirror image for the sake of total hardware failure. This could be in a compressed file to alleviate any piracy concerns?
Thanks
So basically you want to backup your music?
2nd hardrive and some backup software
Mine is backed up onto several dvdr's. This is a part of itunes software and you don't need anything else to do it besides a cd burner. It takes a while but, once you've done it, it remembers what you have backed up and lets you put all the new stuff added since last backup on further discs.
External HDD also works; I did this when my tiny hard drive on my laptop got all bunged up and i wiped it asnd reinstalled everything. Not sure what it does for stuff you bought from itunes store as i never buy anything from them!
I don't use it my self, a friend was under the impression that by coping the iTunes folder to a 2nd HD would enable him to drag n drop to a new HD and would be up and running with all his play lists and the like. I said I doubt that would work due to previous system registry entries. So yes the music is straightforward to sort but what about a archive and reinstall type backup?
Hmmm, I would consolidate the library first. (in itunes go file-> library -> consolidate. Also, go to edit, preferences, advanced and select keep itunes folder organised. Then simply copy the itunes music file over to the external HD.
julianwilson, I noticed this but looked like it would only work with Cd's. Does it work with a ext hd then?
Just copy the "itunes" folder that's in your "My Music" folder
That contains all the library, playlist etc info
to save playlists, ratings etc just go file-> export library. and it will creat a .xml file which contains that data. then simply impoort that to the new itunes
Heck getting lost now, tired and one too many bears. Thanks, tomzo will pass this on to him.
Cheers all for the advice
I back mine up to an external HD but I've also got CopyTrans ([url= http://www.copytrans.net/ ]here[/url]) in case it all goes pear-shaped.
It'll rebuild your iTunes from your iPod - well worth it for $20 and has saved me a couple of times when I've had to rebuild the PC as I've got about 60Gb of music on the sucker.
bbA
