Arghhh...iPhone/wif...
[Closed] Arghhh...iPhone/wifi help
7 Users
Someone please help......I have my broadband all set up and running ok, however the password to access it is stored on the laptop which is not a problem. However when I try and access the broadband through my iPhone it keeps asking me for a password and the problem is I cannnot remember it. Is there anyway I can find this out from my laptop? Help 😡
Posted : 16/07/2009 12:50 pm
press the reset button on the router, this will change the password back to the factory default (will be printed on the router or available online)
then use your laptop to access the router setup page (192.168.1.1) and change the password to something you will remember or write it on the router
Posted : 16/07/2009 12:52 pm
 JxL
yes. find out what IP address is your router:
e.g try 192.168.1.1
are you using mac/pc?
When you connect to the router, you should find the password there on display (again, it depends on what router you have)
Posted : 16/07/2009 12:53 pm
It should be stored somewhere in the router setup so if you navigate there, like you did when you set your router up in the first place, it will be there. Failing I'd suspect that serching for password storage on your laptop would get some results. On a Mac it would be Keychain Access so I'm sure there will be a windows equivalent.
Posted : 16/07/2009 12:54 pm
 JxL
dont forget to connect a new device you also need to enable pairing (on mine hold a button for 5 seconds on the router).
Posted : 16/07/2009 12:57 pm
If its a BT one, its usually on a sticker on the bottom or side of the router.
Posted : 16/07/2009 12:59 pm
Why do you need to enable paring on WiFi? I've done it with Blutooth but never WiFi. Is it an iPod thing?
Posted : 16/07/2009 1:00 pm
Cheers, the router is a belkin one. Will I need the PPPoE or whatever they are from my ISP as well?
Posted : 16/07/2009 1:01 pm
some routers (like my orange livebox) now have a hardwear security device which requires manual input to connect a new device
Posted : 16/07/2009 1:02 pm
onefishin:
It is a new one on me as well.
Posted : 16/07/2009 1:16 pm
No issue with connecting to my wifi router on my new iphone though it accepts any other devices so long as the password's right so I guess it's not set not to.
Posted : 16/07/2009 1:28 pm
Cheers guys, after well and truly screwing it up, it all seems to be working fine now 😀
Posted : 16/07/2009 2:31 pm
