I was jus wondering about the best way to strip them for banana plugs?
It's not abundantly clear..
Send it back and buy a reel of 13A mains cable.
Thanks, you've been really helpful.
With a knife would be my suggestion and then heat shrink the tails
What exactly is un clear ? Surely it’s just a piece of wire that you can strip with a knife, scissors or your teeth ?
Looks like there are 3 layers of outer you need to cut through.
Rather than a knife, I'd use one of these and do it a layer at a time.
Have you got your trousers as well?
Really bring the sound alive!
https://chord.co.uk/chord-epic-speaker-cable-termination-guide-chordohmic-connectors-and-hex-gun/
It’s not abundantly clear..
try wiping off the snake oil and it may be more obvious?
Tough crowd this morning.🥰
Adjustable Cable Stripper to remove the outer sheath without damaging the inners.
I thought £15 per metre for speaker cable was expensive until I found the 600 quid mains cable...
I thought £15 per metre for speaker cable was expensive until I found the 600 quid mains cable…
£600 mains cables are entry level.
That's quite reasonable.
How about:
£4699 mains power cable
You can upgrade the fuse for only another £155 as well.
ChordOhmic banana to banana £120; banana to spade £188; spade to spade £256
That’s quite reasonable.
How about:
That's per meter if you go for all the spendy options.
It looks suspiciously like its been cut out of some old anglespoise lamps aswell..
The mains cables are hilarious. Totally disregard what the rest of your house behind the plug socket and the street to your house are cabled with 😂
Well yes, but have you ever tried having that conversation
An acquaintance of mine is now looking at aftermarket power supples for his turntable. I had pointed out that when he acquired it for a considerable sum in the late 80s, our power came mostly from big spinning rotors next to coal or nuclear boilers which are an inherently stable way of doing things. Now, with our power coming largely from wind, a blustery day would render the thing practically unlistenable. Hook, line and sinker.
You will need a DU blade to get through the 5G tinfoil shield!
I would split down the middle about 10 cm, then remove a layer at a time with a knife in the usual way.
A sharp pair of scissors and a steady hand.
Stanley knife might help split/take the outer shield off.
does it have wide, expressive soundstage with warming timbres?
warming timbres?
What mains cable for my log burner?
warming timbres?
"Alters the frequency response".
You forgot to fit the trousers (with the directional arrow pointing the correct way)
warming timbres?
That deserved more love than it got.
Oh crikey now the plugs are on it does look a bit, well, thin.
How about:
£4699 mains power cableYou can upgrade the fuse for only another £155 as well.
£3230 USB cable
Jeeesus, I hope you get a free box of tissues with those 😉
Looks like the 13A mains cable suggested would be an upgrade! Does a doorbell go on the other end? 😉
This made me laugh out loud though:
"Speaker cable direction
Almost all speaker cables, in fact almost all audio cables, be they for digital or analogue are, in our experience, directional in that the sound will be better with the cable connected in a specific direction. Chord speaker cables should be connected so that the print on the cable reads in the direction of the signal. In effect, the C of Chord should be nearest the amplifier."
This tipped me over the edge
"Burning-in cables
[...] As a general rule though, most speaker cables need at least 100 hours use before all the improvements they will bring to the performance of the system can be properly experienced."
(all this and more at snake oil central )
(Sorry OP - I realise this is like mocking religion :-/ )
True audiophiles don't use mains electricity.
Suck ma bawz.
Soooo.... You go a shielded cable (that speaker cable doesn't need.)
You chopped the shielding away at the end... So you now have an unshielded cable... Good job.
At least Chord don't claim that their USB and ethernet cables improve the audio... although the reviews they link to do. FFS.
Although their sister company English Electric goes full on woo with an audiophile-grade ethernet switch!
Why spend a £20 on a switch when you could spend £450!
Mocking religion?
Get more sense out of a flat earther talking about 5g activated bill Gates particles in the Covid vaccine.
Soooo…. You go a shielded cable (that speaker cable doesn’t need.)
Remember when having your phone near the speaker made it go mad when you got a text?
You chopped the shielding away at the end… So you now have an unshielded cable… Good job.
Yup, that renders it pretty pointless. Surely you should earth the shielding at the speaker (which wouldnt work as cabinets arent metal) and the amplifier.
Surely the biggest hurdle is having to convince the artists to go back and re-master all their recordings using shielded mic cable rather than meerly starquad with XLR ends?
Actually it's perfectly valid to only connect the shielding at one end if you want. It's also valid to not connect it at either end. It depends what you are shielding against and how the noise is being injected (common mode/differential mode). The shielding is much less effective if not connected at either end but it will still do something against some types/sources of noise (but not all)
It is also of course a complete waste of time in this context. See also the noise insulating feet on that ethernet switch FFS. Part of the enjoyment of audio is how much money you burn on stuff that does nothing and if that alters the 'sound stage' then so be it
Actually it’s perfectly valid to only connect the shielding at one end if you want.
I've half a memory that that's exactly what you're supposed to do, but cannot now remember the context where I heard that.
I can beat that. I defy anyone to improve on this peak audiobollocks: http://www.enjoythemusic.com/hificritic/vol5_no3/listening_to_storage.htm
I think this comes close.
https://www.lessloss.com/blackbody-p-200.html
Or how about $4200 speaker feet
I’ve half a memory that that’s exactly what you’re supposed to do, but cannot now remember the context where I heard that.
it depends on what you are shielding against and why. Sometimes you want to create and extended 'pipe' from one piece of equipment to another by using foil shielding and connecting at both ends. Sometimes that makes things worse. The end you connect at depends on the source and what you are shielding against and why
When I used to design stuff we would start with what we thought was best but then try other stuff as well as it's not always obvious what the worst source of noise will be
In this case of course the noise is all in the marketing
From that last link
...The optional organic glass stand, custom made to your specific latitude...
it's like they are having a contest to see how far they can take the piss and get off with it
Anyone want to start a co doing premium bike shifter cable, ultra low friction brake oil and Di2 signal cleaning stickers 😂
It's not crystals and ley lines.
Can we make something with crystals and ley lines?
I reckon we could swing a genuine audiophile product involving crystals and ley lines.
Include a free druid or virgin or something.
You called?
Nope, i do remember when the tiny interference was picked up by the amplifier or line cables between source and amplifier and amplified so you can hear them in the speakers though.
You even pointed out yourself cabs aren't shielded so it would still happen.
You want crystals?
And why does my youtube link not work?
Open a new tab, find video on Youtube, click "SHARE", click "COPY IMBED LINK". In the STW Reply box just paste the link. No need for the "[VIDEO]" HTML tags.
Mobile is the same, use the youtube APP, same as above.
