Anyone recommend an...
[Closed] Anyone recommend an aftermarket head unit that...
10 Users
...has DAB and USB iPhone/iPod input.
Either double or single DIN, and not really bothered about a CD slot either.
What should I be looking at?
Ta!
Posted : 26/11/2014 7:02 pm
DIN as in [img] [/img]?
Posted : 26/11/2014 7:04 pm
DIN-E is the standard fitting as seen in every car ever since about 1980, up until they started integrating them into the dashboard (and even then a lot of them are 'double DIN', a double-height DIN-E).
Posted : 26/11/2014 7:08 pm
Thusly,
( https://en.wikipedia.org/wiki/ISO_7736
I'm old enough to remember DIN-D, which was a smaller standard popular with those crappy radios with a volume knob on one side and a tuning one on the other and huge mechanical preset buttons.)
Posted : 26/11/2014 7:10 pm
How much do you want to spend and is there aftermarket amps and speakers involved etc?
Posted : 26/11/2014 7:11 pm
Interesting. Cheers Cougar!
Posted : 26/11/2014 7:17 pm
 Olly
skys the limit. I wanted DAB and USB but had not intentions to mess about with the rest of the system. Also was only ever going to have it welded onto 6 music so wasnt too fussed about how snazzy it was.
I have two of these. one in the car, one in the van. Sound is lots better than standard once youve put "loudness" on and set up the eq.
http://www.halfords.com/sat-nav-audio/car-audio/dab-radios-car-stereos/sony-cdx-dab500u-dab-car-cd-player
you will probably need to add a DAB aerial of some sort. I went with a super budget magnetic roof jobby that hangs out the back door on the car (i dont use the doors, so it isnt in the way) and a proper fitted on on the van as i was already having the headlining down.
Posted : 26/11/2014 7:23 pm
Alpine have always been the go to headunits for me. Last one i had was i pod usb card and bluetooth ready. The ipod had a slot it went into behind the facia. It also worked with the steering wheel controls on my car.
I fitted a Sony single DIN to Mrs Blazin's car recently DAB and iPod/USB in, works a dream and was about £70 new and boxed from a seller on eBay.
Posted : 26/11/2014 7:32 pm
I've got a Kenwood DAB unit, predecessor to this one:
http://www.halfords.com/sat-nav-audio/car-audio/dab-radios-car-stereos/kenwood-kdc-dab361u-car-stereo-with-digital-radio
For £100 you really can't go wrong, it's got a front USB socket, it's actually on the right of the unit, behind a little clear plastic flap that flips back, the DAB reception around where I live, Chippenham, is generally really good with only the little stick-on windscreen antenna; I've driven down to Weston-Super-Mare on the M5 and only lost signal on the elevated section a couple of miles south of Avonmouth.
I lose it from Devizes across to Salisbury, though, but I hardly ever go that way anyway.
Great little unit, simple to use, I've had an Alpine unit which had an iPod interface, and it was a pig to use, horribly unintuitive interface, just changing the time on the clock was an exercise in tear-inducing frustration.
Volume up/down buttons are a no-no, a knob is essential.
Posted : 26/11/2014 7:46 pm
I have an amp and a good set of 9x6s so it's just the head unit. And yeah, mainly for 6music.
Budget - dunno, probably no more than £150 - £200 or so, although if that Sony is any good and it's only £90 then that'll do me. :o)
Posted : 26/11/2014 7:50 pm
Does that Sony (or the Kenwood) work with Spotify via USB?
Posted : 26/11/2014 7:53 pm
http://www.caraudiodirect.co.uk/pioneer-deh-x8500dab
Good unit that works with iplop 5 and maybe 6 I believe.
You might want to save some pennies for a decent dab aerial
Posted : 26/11/2014 8:01 pm
The DEH-X range from Pioneer are good, if you get it right with Halfords you'll get 10% off on a Friday when they do 10% off between 12 and 2. The 8500 does handsfree phone as well as playing the tunes from your phone, it has a rear USB out/in unlike the cheaper ones which are front facing only.
I was pleasantly surprised at how good DAB reception was with a screen mounted powered aerial.
Posted : 26/11/2014 10:40 pm
