Any STW electrician...
[Closed] Any STW electricians? Economy7 advice please
7 Users
Hi, I'm buying storage heaters but a mate thinks that my meter needs to be made economy7-capable before it will work (*). The confusion lies in whether or not the existing meter (which does seem to have 2 rates) is already economy7, I think it is but then what do I know. I think that everything is ready for the electrician to do his stuff but I can't be sure. From the photo is my meter already economy7 and "ready" for an electrician to complete the work or does the Electric company need to install anything extra beforehand?
* The heaters are dual storage and convector, so I know the convector will work regardless, it's just the economy7 storage part that I'm unsure about.
Posted : 08/03/2011 2:56 pm
bump
Yes I accept that the electrician will know but thought I'd ask in case it's obvious to someone here...
Posted : 08/03/2011 7:45 pm
Used to work for British Gas - you need to get a new meter installed. Call your power company. If you don't have a 2 rate meter installed then the heaters will either a) not come on, or b) eat all your money. E7 has a slightly more expensive day rate for normal use and a night rate which is about 1/4 of the price, for charging the heaters, which then release the heat during the subsequent day.
Hope this is of some help!
Posted : 08/03/2011 8:02 pm
Cheers Mulacs, the small grey box with the LCD display appears to be 2-rate so I'm hoping I dont need to change anything and just get the electrican to connect to the existing stuff
Wish I knew more about this!
Posted : 08/03/2011 8:09 pm
Is your electrician gonna change your distribution board whilst hes at it?? Is there already some kind of wiring in for electric heating already??
Posted : 08/03/2011 8:35 pm
We had 2 meters one for cheaper rate electric, that span round like a downhillers front wheel, and an ordinary meter , we got charged standing charge for both meters,, als get your sparky to put a few spurs off the circuit for cheaper rate power for the tumble dryer wshing machine and possibly other stuff you only need to use at night.
Oh and i had the second meter taken out, as it was to costly to ever use the underfloor heating after the first month, that was 20 years ago.
Posted : 08/03/2011 8:37 pm
looks like the 2 rate one we had in our place.
funnily enough we had it taken out as we don't have storage heaters and use most leccy at 'peak' times.
Posted : 08/03/2011 8:40 pm
If there isn't any wiring in already its more than likely that some form of RCD protection would be required, which may mean a fuse board change. There will be two power supplies going to the heater, one for the storage(economy7) and one for the convector.
I fitted a Dimplex Storage heater with convector a while ago. Bloody horrible things to put together.
Posted : 08/03/2011 9:05 pm
I do hope you have strong floors 😉
Posted : 08/03/2011 9:41 pm
