Any Plumber/boiler ...
[Closed] Any Plumber/boiler fitters on here?
6 Users
 hora
As a punter I was abit alarmed about this. Mid-new boiler fitting whilst removing the cylinder water has leaked through into the kitchen ceiling around the light fitting etc.
The old heating control panel has a mass of wires sticking out of the wall and the old immersion switch for the cylinder has been opened with all three wires hanging out.
I am mindful that this is mid-job in a unoccupied house however is the plumber sufficiently trained to cope/safely seal off these items without bodging it? (i.e. remove and deal with the immersion cabling and other associated wiring etc effectively?).
He also added that leaking happens sometimes and its not a biggie.
In addition after pulling out the old gas fire in the living room I discovered the (lead) gas pipe that fed the fire actually ran that the concrete hearth. Can he pull that out from under the fireplace back to the source and seal off easily enough? Its not a big job if the pipe is accessible? He mentioned by law his not really supposed to cap lead piping.
They are coming back tomorrow to finish. I'm new to all this and don't want to have my trousers pulled down or have to call in an Electrician unnecessarily.
Posted : 28/09/2010 6:06 pm
Who knows if your plumber is able to do this? It is very simple to do however. One connection for each of the electrical devices to isolate them - both at a fused spur point. Or isolate at consumer unit - immersion is probably on its own circuit, boiler probably on a spur on the ground floor ring main
Lead pipe - ignore it and cut / cap near the meter where it should be copper - if it is still connected
Posted : 28/09/2010 6:20 pm
All gas safe plumbers should have defined scope part p certification or whatever they're calling it this week.
Posted : 28/09/2010 6:24 pm
Could you translate?
Posted : 28/09/2010 7:22 pm
 hora
Thanks guys. I'm just abit shocked possibly worrying too much. Maybe I shouldn't have appeared mid-job and if it was an occupied house they might have been less blasé?
Posted : 28/09/2010 7:33 pm
The most basic electrical qualification is a domestic installer course.
It's basically a 5 day course with exams at the end. There are 2 levels, A and B.
A is full scope and includes everything domestic, consumer unit changes, full rewires and even 3 phase.
Level B is defined scope, suitable for plumbers and kitchen fitters etc. Allows for extra sockets, new radial circuits, wiring in a cooker, shower or boiler.
After that there are the various C&G qualifications, leading to full contractor status.
I'm domestic only, did the 5 day full scope course, then did the C&G 2382 and 2392.
Posted : 28/09/2010 9:15 pm
 TimS
I've seen a few professional jobs where the only thing that made the work 'professional' is that someone paid to have it done. I'm sure plumbers/sparkies are better trained thesedays
Posted : 28/09/2010 9:46 pm
Better trained and certified maybe. In my experience most plumbers and electricians are bloody animals who leave a trail of destruction behind.
Posted : 28/09/2010 10:02 pm
 hora
TheFunkeymonkey- is it normal though? As described above. To me (non-professional) it looked like rampant chaos was going on.
Posted : 29/09/2010 7:05 am
The power to the circuits should be off at the source really. It's good practice to work that way, not only for the customers safety but the tradesman also. Bare cables should always have some sort of protection over them, even if it's just a bit of tape. It's easy to re-energise the circuit by accident and brush against a bare cable.
As for The leaks, it happens. It's not normal and he should be being careful with dust sheets down too. But it does happen.
Sounds like he's being a it lax because it's an empty house.
Posted : 29/09/2010 7:12 am
 hora
I know which way the thick immersion power cable runs (its currently exposed from its beading down through the kitchen) so when I meet him today to hand over the money and its still there I'll ask him to chase it back to the source first. No way I want any live wire(s) left anywhere for the future- beit me, a tradesman or future owner. Especially with the size of it.
Posted : 29/09/2010 7:18 am
 hora
TheFunkyMonkey- YGM. How much do you charge for coming out/checking and possibly rectifying (for peace of mind).
Posted : 29/09/2010 10:29 am
1lb of bacon, 12 eggs and a bag of spuds
Posted : 29/09/2010 10:41 am
I think you need to included those "competent persons" that the domestic installer schemes are spewing out as well.
Posted : 29/09/2010 11:49 am
That'll be me then 😉
Posted : 29/09/2010 12:00 pm
