Any locksmiths abou...
[Closed] Any locksmiths about?
6 Users
Moving house soon - a decent shed exists but the lock is broken and I can't get in. Anyone know roughly what sort of a price a locksmith would charge to open the door and fit a new lock?
Posted : 01/02/2009 11:20 am
Most sheds have a generic mortice lock with a very standard key, would you like me to send you one?
Posted : 01/02/2009 11:24 am
That would be great if you don't mind - at least I could try it then. What's your email - I'll send you my address.
Posted : 01/02/2009 11:40 am
djhATcando4youDOTcom
Posted : 01/02/2009 11:41 am
How is a new key going to help if the lock is "broken" ?
Also not sure about most sheds having "generic mortice locks". A mortice lock for a garden shed is fairly unusual I would have thought.
Just my opinion though.
Posted : 01/02/2009 1:02 pm
Not sure gus....but since the kind chap above is going to send me a key I'll give it a go before getting a locksmith out.
Posted : 01/02/2009 9:04 pm
A locksmith will probably charge £50 callout, surely it would be cheaper to break in and make good on a DIY basis.
Posted : 01/02/2009 9:20 pm
most sheds have external hinges just unscrew the door
Posted : 01/02/2009 9:43 pm
Paul - it does, but many of the screws are completely rusted and getting purchase with a screwdriver has proved beyond me!
Posted : 01/02/2009 10:00 pm
Hack Saw or just drill off the heads with a sharp bit.
Posted : 01/02/2009 10:01 pm
Yeah I would go for mikey-simmo's suggestion. Obviously attack the screws on the frame rather than the ones on the door. Also if you can carefully hammer a electricians bolster behind the hinges, I think that you might be surprised just how easy hinges can be prised off.
Once opened, I suspect that you'll find that you have a rim lock which will be easy to unscrew and replace.
As I suspect that the problem is very likely to be that the lock has become corroded and dry inside (specially if it hasn't been opened for a long time) before you get all heavy-handed with it, it might be worth spraying some GT85 through the keyhole first. Better still squirt some oil in if you can - and dip the key in oil. If still no joy, force the key round by gripping it with anything that you can - even if the key breaks it's still worth trying as the lock will have to be renewed anyway, and you might find that it suddenly releases.
Finally, you could also try to get a bolster between the door and the frame and prising the two apart - it's very possible that you will be able to move it 5mm or so which might be enough to force the door open.
Posted : 02/02/2009 12:34 am
