Any Car Mechanics c...
[Closed] Any Car Mechanics can Help Me?
5 Users
Got a puzzling problem with my car: Ford Focus Diesel '02 if anyone can help, I'm no mechanic but I've got freinds who are car savvy and are a little stumped.
Basically about 6 weeks ago my car wouldn't start in the morning-flat battery, freind came down and ran tests on it, altenator was charging fine, he thought it was battery or smart system on car.
I bought a battery and it ran well for a month, now it's dead again. Recharged battery at home yesterday and now it won't start with a full battery?
Spoke to my mate who said it could be the main earth? A lad at work said could be an eath to the starter motor, altenator?
Help!
Posted : 07/01/2016 6:57 pm
1.8 tddi?
Bad earth would have it konking out whilst moving (Least it did on my escort van with the 1.8 td engine)
I'd suspect a constant drain somewhere - lamp in glovebox/boot/sidelights (does your lights on warning noise work?)
Your new battery could be borked from the total drain?
not a lot of help, sorry.
Posted : 07/01/2016 7:16 pm
re-do the earths. what is the current symptoms with not starting? Does the dash light up, starter motor turn etc?
Posted : 07/01/2016 7:30 pm
Yes mate.
My brother suggested a drain, possibly the boot light. Going to check it out tomorrow if possible, the battery was fully charged though.
Dash lit up like a christmas tree this morning, then starter motor idled in that horribly moany way and then nothing. Not the click of a dead battery.
Posted : 07/01/2016 7:31 pm
really does sound like the wiring. give the wires next to the crimps a flex and see if they fall apart (like the rest of a ford) and if the wire is sound then undo the mounting point and clean it up with a wire brush and refit.
Check all of them and both ends - main earth, starter and alternator. Sounds like the starter wiring tbh though.
Posted : 07/01/2016 7:34 pm
Crimps?
I'll have a butchers tomorrow at those.
Posted : 07/01/2016 7:50 pm
What battery did you fit? With the smart charging system a calcium battery is required as its charged hard then the alternator cuts charge to save fuel. I think a cheap battery will can be killed in a few weeks.
I had cold starting problems with one of these, had loads of parts changed by so called experts. Problem was a piece of metal had found its way into starter motor and was shorting, draining current and sending the ecu into a frenzy. Only found out after 6 years when the starter motor failed and I opened it up.
Posted : 07/01/2016 8:06 pm
Easy way to identify earth problems is to get a set of jump leads and use them to create a temporary earth. Use one lead to connect earth to a chassis earth point, if no improvement move the lead from chassis and clamp to engine block.
A multimeter will often show good earth continuity but under a heavy load such as starting a poorly terminated earth will have a high resistance.
Is the battery definitely charged? If unsure, it should read about 12.7v. 12.4v is 50% discharged.
Posted : 07/01/2016 8:23 pm
