anti mould sprays
[Closed] anti mould sprays
10 Users
are they all the same? I need to clear some mould on tenanted property windows. Screwfix do one for a fiver, anyone tried it? thanks in advance
Posted : 14/02/2013 10:54 am
I just use Flash Bleach spray - what it doesn't remove it bleaches so you can't see it so obviously (you never hide it entirely if it's eaten into the surface).
Posted : 14/02/2013 10:56 am
I use the one from Screwfix (damp behind wardrobes on a gable end wall) and it works fine. Just follow the instructions and ensure you get all the spores off.
Posted : 14/02/2013 11:05 am
My dad got some of this for cleaing the frames of UPVC windows, to get rid of the little black spot mould.
http://www2.westfalia.net/shops/household/cleaning_and_protection/mould_and_dampness/dealing_with_mould/182069-mould_stop_mould_ban.htm
Did the job and nothing grew back.
thanks - I'll order some of the mould stop on last link - much appreciated. STW to landlords rescue!!!
Cheers all
Posted : 14/02/2013 11:13 am
Surely warm water with 5 - 10% bleach would do the job cheaper...
Posted : 14/02/2013 12:35 pm
the dettox stuff always works well for me
i also leave it for much longer than it says, with very good ventilation, and then wipe it up after (be careful and read why ventilation is important - it is nasty stuff)
has so far kept mould off an external wall very well
Posted : 14/02/2013 5:19 pm
Mould remover to end all other mould removers IMO. http://www.cleanstore.co.uk/products/Product.asp?ID=2749&?utm_source=googlebase&utm_medium=comparsionshopping&gclid=CPKGpfi9trUCFabLtAodEFoAuA
If Heineken made mould remover etc 🙂
Posted : 14/02/2013 7:01 pm
any sodium hypochlorite solution will so the job. The main thig is to make sure that it's not as a result of a leak. if it's just on windows then make sure the relative humidity is less than 50% or that there is sufficient air flow and that'll stop any propagation or regrowth.
Posted : 14/02/2013 7:38 pm
White vinegar, lemon and water in a sprayer bottle works a treat!
Posted : 14/02/2013 7:40 pm
*bookmark*
Posted : 14/02/2013 7:45 pm
