Alu bar - engineeri...
[Closed] Alu bar - engineering companies and offcuts.
9 Users
Do engineering companies pretty much use all their offcuts? I need some alu bar for a project with some school kids, about 4 sections of 30mm by 60mm. Do engineering companies scrap this kind of size or do they use everything? Dont wanna ring round and annoy a load of people if its something they arent gonna have.
Posted : 18/01/2011 10:02 am
We get almost all of it recycled as it's better environmentally and obviously gets us some cash. That said, that sort of size would probably not be a problem to give away (not us, I'm afraid, we're a steel/Ti place).
Or ebay is great for this sort of thing.
Posted : 18/01/2011 10:06 am
If you mean 4 lengths of a bar which is 30 x 60 then it depends on the lengths. Most engineering companies will have scrap metal collected but if you are after small offcuts I would have thought they would give them to you.
It really depends on who you get to speak to. You will just have to ask, I have always found companies very helpfull if it is going to a good use.
Posted : 18/01/2011 10:08 am
send someone hot in to ask. our entire uni course used to send 'the hot girl' (well it was engineering!) in for our stuff- most of it free or trade!
Posted : 18/01/2011 10:14 am
 cp
We use every last bit of everything generally, off cuts go on a shelf to be used up.
I assume you mean 60x30 in profle - what sort of length are you talking about?
+1 on ebay etc... also worth calling your local stockholder rather than individual engineering companies.
Also be aware that alu is often stocked in imperial dims, so might be worth banding around a few imperial dimensions to companies - i.e. if the 30mm can be 1 inch then you'll probably have more luck.
Posted : 18/01/2011 10:20 am
Anywhere using significant amounts of metal will have a scrap bin.
Ours is full of old bus bits, if you can find somewhere that does a lot of aluminium manufacturing, theirs will be full of aluminium scrap.
It's always worth going in the back door and speaking directly to the guys in the workshop.
There's a good chance they'll let you have a few bits for a donation to the tea kitty.
Posted : 18/01/2011 10:21 am
Why not pop in to your local scrap yard?
Posted : 18/01/2011 10:24 am
a number of small engineering shops etc sell small offcuts and ends etc on ebay:
see:
[url= http://shop.ebay.co.uk/?_from=R40&_trksid=m570&_nkw=aluminium+bar&_sacat=See-All-Categories ]Click Link for Ebay listing[/url]
Sorry round bar 30mm diameter 60mm long x4
So you reckon they should be amicable, could send one of the kids in.
Or scrappies should have alu bar?
Posted : 18/01/2011 11:07 am
Have you tried Aluminium Stockists? There's loads about and they often cut lengths to suit so should have off cuts. The closest you'll get in imperial will be 28.575 (1 1/8) or 31.75 (1 1/4)
A google search will bring up loads of stockists.
Posted : 18/01/2011 11:19 am
