Air cooled engines
[Closed] Air cooled engines
Why do they sound different to water cooled ones?
I ask the question because I know beetle engines are that way inclined and I heard an advert on the radio that had a big air cooled Harley in the background, similar sound.
Do they have to have a different firing sequence or something?
Posted : 18/07/2012 12:06 pm
less sound insulation around the crankcase, cylinder heads etc was always my thoughts.
Posted : 18/07/2012 12:08 pm
Might be the fins vibrate and work as a sound source.
Posted : 18/07/2012 12:10 pm
 momo
Which water cooled engines are you comparing them to?
Beetle used a flat four (boxer engine) - the same layout used by subaru, which have a similar exhaust sound.
The Harleys run a large capacity undersquare (stroke > piston bore) v-twin. Most cruisers which run a similar layout sound the same.
Posted : 18/07/2012 12:18 pm
Beetles are boxer engine configuration which gives them their sound. Not sure for reason of air-cooled engines in general sounding different.
Posted : 18/07/2012 12:20 pm
i can spot a beetle/aircooled vw van by the noise. i always assumed it was the limited exhaust run/loose bearings/noisy tappets/general impending calamity that created the whole noise effect.
love it. too many good memories associated with the noise.
Posted : 18/07/2012 12:22 pm
As stated above, the aircooling itself isn;t responsible for the sound - it's the engine configuration. It so happens two well known aircooled engines have a distinctive note.
Last aircooler I drove was a [url=
which sounded lovely and smooth.
Posted : 18/07/2012 12:24 pm
Air-cooled engines in cars usually have a dirty great fan - that makes quite a contribution to the distinctive noise.
Posted : 18/07/2012 12:32 pm
Design of the engine & the fact that there isn't a water jacket around the engine muffling any sound!
Posted : 18/07/2012 12:37 pm
less insulation (to allow air passage)
Posted : 18/07/2012 12:39 pm
[i]Which water cooled engines are you comparing them to?[/i]
Say, a standard Focus and a Japanese sports bike. I know they're not really like for like comparison but the two engines mentioned do have a fairly similar sound. i'm happy to accept that not all air cooled engines sound like that though.
Posted : 18/07/2012 12:56 pm
There's a 'tuned' (actually probably detuned with the state of the UK tuning scnene) Imprezza (water cooled) near my mums that sounds exactly like an old air-cooled VW camper van.
Posted : 18/07/2012 1:28 pm
Well, comparing an aircooled VW engine to a Focus is like comparing an abacus to a PC, for a start! Totally different! 60 Years + of development and different cyclinder layout
Compare, say an older air/oil cooled GSXR 750 engine to a moderen GSXR 750 engine and they'll be very much the same as the layout is the same
Posted : 18/07/2012 1:52 pm
Had aircooled VWs and now have wasserboxers - the sound is a little less brash but that is due to better exhaust systems, but the underlying burble is the same.
Posted : 18/07/2012 2:08 pm
Near to me a (frickin' awesum!) family has a T1 transporter and a t25 which recently-ish had a subaru boxer fitted. To my ears, at parking/pulling-off-up-the-road speeds, all three engines sound more like each other than they do to water-cooled 'inline' 4 cyl petrol engines (tht 'burble' as above). But again as mentioned above, there is also the exhast to consider: I am sure the subaru boxer would have sounded different in the front of its donor car with a longer exhaust system too.
FWIW, for the same reasons of timing/clylinder layout rather than cooling arrangments, my VW van-salesman-and-petrolhead mate swears that a 5 cylinder T4 tdi engine at high revs sounds quite a lot like the original 80's 5cyl(petrol of course) quattro that shares the same engine block (but nothing else of course). I have never been in a quattro so I'd have no idea, but my t4 does has rather a fun growl (for a diesel!) at 3000+ rpm...
Posted : 18/07/2012 4:23 pm
A harley crank is offset so the 2 cylinders are out of phase, the Buell version has a crank that is in the same plane. (iirc)I believe the tuned versions use this design of crank too.
Posted : 18/07/2012 4:38 pm
This has a 2.2 Scooby lump in and it sounds not unlike the 2.1 it replaced:
Posted : 18/07/2012 4:39 pm
to prevent over heating aircooled engines have fewer, bigger, slower revving cylinders, hence a deeper boomier sound? just a thought
Posted : 18/07/2012 4:40 pm
*dribbles a bit at rogerthecat's synchro* ๐Ÿ˜ณ
Posted : 18/07/2012 4:41 pm
don't scoobys fire like a pair of twins? e.g. where 2 cyclinders fire on the same stroke leaving 2 power free strokes from each 4.
or do the fire as per a straight 4? e.g. one cyclinder fires on each of the 4 strokes. I remember reabing some WSB stuff a few years back that the twins could put their power down better with 2 more powerful blips of power that the 4 closer spaced. might be the same for scoobys in WRC.
if so than that'd explain the twin like burble as per Harleys
+1 on short exhausts and less insulation from water jackets too though
Posted : 18/07/2012 4:52 pm
the aircooled engine in my old Beetle was pretty silent most of the time, sometimes it sounded like a screaming starter motor, other times it made loud banging noises when the cylinder heads cracked.
but when it was working the stainless exhaust made is properly loud.
Posted : 18/07/2012 4:54 pm
Water jacket can silence an engine a bit (when a mate's SV650 lost most of its coolant, I noticed because when we next stopped it sounded a bit louder and sharper.
Posted : 18/07/2012 6:40 pm
What, farty noises?
Like this air cooled Double Wasp...
Compared to this liquid cooled V12?
Posted : 18/07/2012 8:43 pm
