Downloaded Blackberry from the CD onto my PC now every morning it opens itself automatically first (I clicked on the option not but it still does). Using the standard My computer/unistall programme, the Blackberry function suddenly kicks into life again and suggests you upload more info from it to then uninstall (wtf?). Then it says error message/close.
So I'm left with a really slow PC with ctr-alt-delete being my morning ritual.
Is there an online more aggressive software removal tool that anyone can recommend?
You could always uninstall, then go into the registry and remove any Blackberry info there before reboot... that should stop it trying to reinstall itself 🙂
add/remove programme?
or
CC cleaner
I don't have a problem with the BB software starting up. Not sure what you're doing wrong there.
Can also run MSCONFIG to remove things from windows start up
Yeah, Start -> Run -> MsConfig (or Start, type MsConfig in the box if you're on Vista/7)
'Startup', uncheck the blackberry program.
Restart
I use this...its a portable app too - no install required
http://www.portablefreeware.com/index.php?q=revo+uninstaller&m=Search
Spybot S&D also has an uninstall feature, plus disabling applications which start at login.
Revo did it. Took a while though with the Blackberry pop-up trying to 'muscle in'. Wierd it was acting almost like a virus. Thank you ericemel
and thank you guys 🙂
