Accurate car tyre s...
[Closed] Accurate car tyre specs online
16 Users
I'm sure (or I was) the Passat is 205/55/R16, but when I type my reg no into one of the tyre sites I get 215/55/R16. There are car data sites out there and they say 205.
Anyone know of a good and accurate way to get the tyre spec? Before anyone asks, I'm nowhere near the car so I can't go and check!
Posted : 20/07/2015 4:28 pm
Ring a VW dealer
Posted : 20/07/2015 4:33 pm
A dealer is going to be the closest you're going to get to definitive short of a visual inspection (assuming a previous owner hasn't fitted four incorrect tyres). For online, Blackcircles has an 'enter your reg' checker IIRC.
Are you remembering the size of the spare wheel, perhaps?
Posted : 20/07/2015 4:43 pm
205 is far more common and cheaper. Only 10mm difference. Can be quite a variance in spec sometimes as well as people making adjustments for ride/look/price. I wouldn't get too hung up on it, either will do.
Posted : 20/07/2015 4:54 pm
Incidentally,
If you've got undersized tyres fitted, it'll cause your speedo to over-read even more than it does normally, so you'll be driving everywhere slower than you think.
Posted : 20/07/2015 5:04 pm
Can you not just go by what the current tyres are? The online no. plate checkers are notoriously unreliable...
Posted : 20/07/2015 5:16 pm
 P20
What does it say on inside of fuel flap or wherever else they've put the tyre pressures?
Posted : 20/07/2015 5:40 pm
 br
Maybe it should have 215's on, and you put the wrong ones on last time?
Posted : 20/07/2015 6:07 pm
I could go by the current tyres uf I were with the car, but I'm not, and I want to order the tyres now...
Some sites list both 205 and 215 for the same model.
Posted : 20/07/2015 6:34 pm
Is SWMBO close to the car? Phone her and get her to have a look. Use the helpful guide on Black Circles to show her what to look for.
Posted : 20/07/2015 7:38 pm
No, we're both here. Will have to call the dealer tomorrow.
Now I'm thinking they might be 215 because they are all £90 ish whilst 205s are £60 ish, and I definitely paid £90 a corner last time.
Posted : 20/07/2015 7:53 pm
stick 205s on, you will get a much better tyre for less money than the wider ones
Posted : 21/07/2015 8:16 am
Why so much difference?
My Galaxy runs 215/60/r16's, of which two need changing next week. What are the issues with dropping a tyre size?
Posted : 21/07/2015 8:23 am
I'm more concerned about what the insurance company will say.
Difference in price is down to supply and demand.
Posted : 21/07/2015 8:26 am
Just checked online, 205s are 1.7% smaller than 215s.
On that car the speedometer does not read the usual 10% under, it reads about 6-7% under. So if I were to fit 205s it would bring it more into line with other cars I've had if I were to simply ignore the difference and continue to cruise at an indicated 70.
Posted : 21/07/2015 8:34 am
In other news, I need to take a dump at some point, do I do it now, or wait until the last minute of turtle heading so the relief is more intense?
Posted : 21/07/2015 9:04 am
Definitely the latter.
Posted : 21/07/2015 9:09 am
Am I missing something here? 205/215 refers to the width of the tyre carcass, 55 is the profile, so a 205/55 and a 215/55 should have the same outside circumference, so there should be no effect on your speedo. If you were dropping wheel size from 205/55/R16 to 205/30/R14 then maybe ...
Posted : 21/07/2015 1:56 pm
yup. how tyre sizing works 😉
the profile is a % of the width so a wider tyre with the same profile has a larger circumference.
Posted : 21/07/2015 2:09 pm
Could be either, cars often come approved for a few sizes. Its all in the manual.
Posted : 21/07/2015 2:23 pm
It doesn't always work. My car was supplied with inch bigger alloys than the car reg plate sites say but the bigger size is correct on the dealer systems.
Posted : 21/07/2015 3:07 pm
Mine has it in the owners manual for the two wheel sizes that it came out of the factory with.
Posted : 21/07/2015 4:00 pm
A ha! That would explain it. Every day is a skool day 😳
Posted : 21/07/2015 4:16 pm
