Accuracy of myfitne...
[Closed] Accuracy of myfitnesspal
10 Users
I just came back from a vigorous road ride of about 100 minutes, and MFP is telling me that I burnt 1550 calories. That seems quite high, especially considering I am not exactly suffering for it. Does anyone have any sense for how accurate MFP is in terms of the calories it allots to different exercises?
Posted : 18/07/2015 12:32 pm
I find MFP to be extremely 'optimistic' in terms of calories burned during most exercises. I've linked strava to it now as that seems a little more realistic for runs and rides.
Posted : 18/07/2015 12:41 pm
It is a reasonable guide. In the past it has tied in pretty close to what my Garmin gave me but I always think it is overly generous in its estimations.
Its never going to be the most accurate thing in the world...
Posted : 18/07/2015 12:42 pm
It's not an impossible figure. Assuming that the app knows accurate how much energy you've used (which on a road ride it should be able to make a reasonable guess), then it's down to what percentage efficiency myfitnesspal thinks you convert calories to mechanical energy. Typically the range is 20% to 25%, which depending on what value they use gives a potential overall error of about 20%
Posted : 18/07/2015 2:12 pm
Are any of the GPS etc apps accurate? Garmin and endomonmdo seem way over the top to me.
Posted : 18/07/2015 2:16 pm
Assuming you're on the road they should be reasonably accurate , well within the error above.
This is from the last 90 min road ride with a power meter
.............................avg power.....Work Done......Kcal
Garmin................214................1210kj.............1277
TrainingPeaks...214................1207kj...............1207
Strava..................215................1212kj..............1352
They all pretty much agree on avg power and work done (which you'd expect)
There's a bit more variability on calories but all roughly in the expected ball park.
Going back to the OP 1500cals over 100minutes would need an avg power of ~ 258 Watts, which is ~ 22mph on the hoods on a flat road. So if the OP did 35 miles on flattish roads, then the figure would be about right.
Posted : 18/07/2015 3:31 pm
 beej
You may not know, and it might be of vague interest.
Training Peaks converts kj's recorded by the power meter to kcals 1:1.
The conversion ratio from kjs to Kcals is almost exactly balanced by the efficiency of Kcals of food to kjs of output for the average human.
Posted : 18/07/2015 4:11 pm
I find mine can be a mad at times, for example it might give me 700 cals for a ride, then add 1000 more for extra steps at the same time, it does self-correct after a while though.
Strava isn't a great feed for cals though as it doesn't allow for terrain -doesn't matter if your climbing on a road on a road bike, or hopping up rocks on an mtb the count is the same.
Posted : 18/07/2015 4:16 pm
I use mfp and sometimes think 'I just swam off 711 calories?' It lies!
Truth is - I don't know whether mfp calculations of exercise cals accounts for body weight and current daily intakes etc
Reading elsewhere - an hrs swimming can range between 413 calories burned up to 931calories. So 711 seems about right for my weight and speed at least based on the below:
[url] http://www.active.com/triathlon/articles/how-many-calories-does-swimming-burn [/url]
A 130-pound person swimming freestyle for one hour will burn 590 calories swimming fast, and 413 calories swimming slower.
A 155-pound person swimming freestyle for one hour will burn 704 calories swimming fast, and 493 calories swimming slower.
A 180-pound person swimming freestyle for one hour will burn 817 calories swimming fast, and 572 calories swimming slower.
A 205-pound person swimming freestyle for one hour will burn 931 calories swimming fast, and 651 calories swimming slower.
Posted : 19/07/2015 8:15 am
Calorie estimates are generally imprecise unless you have something like a heart rate monitor or power meter to help guide the estimation. Even those can be way off. I find Strava the most consistent and conservative in its estimates, whereas Endomondo is all over the place.
Posted : 19/07/2015 8:37 am
Polar are meant to hold the algorithm for the best guess. IMO the Garmin one is laughably over optimistic. No way do I believe you'd burn 1200 calories in 90 minutes as per Ian's stats.
Posted : 19/07/2015 9:00 am
