3M VHB tape - which...
[Closed] 3M VHB tape - which one?
 Rik
So many numbers and options
I want to attach a smooth oak magnetic knife board (will hold 8ish big kitchen knifes) to a polished quartz splash back?
Which one would be best for max 5kg total weight?
If we move house I’d prob want to remove the board and clean up the tape residue which looks like it’s reasonably easy with wd40?
Posted : 03/09/2020 12:56 pm
I use a lot of 3M VHB at work. We use RP45 which seems to stick most things to most other things!! Good luck separating it afterwards (let alone removing the residue) - the 3M recommended removal tool attaches to an air-chisel 😂
Posted : 03/09/2020 1:19 pm
last time this came up someone recommended Sanojtape, which I bought and it seems work very well
https://www.amazon.co.uk/Sanojtape-Permanent-Automotive-Waterproof-Thickness/dp/B01M2ZVGDF
Posted : 03/09/2020 2:08 pm
 Rik
Hmm...not to keen on taking a air chisel to my kitchen!
I will have a look at the Sanojtape - cheers
Posted : 03/09/2020 4:15 pm
 Rik
What do we think about 3M Command™ Large Black Picture Hanging Strips?
The large comes with 4 strips which say will hold 7.2kg
Posted : 03/09/2020 4:21 pm
Cheese wire or pallet strapping for removing.
Apply plenty of pressure when you fit. Leave it a couple of days before putting any load. Obvs proper clean / degrease both surfaces before applying tape.
To be honest VHB prob overkill if inside. Any decent foam tape will do this.
Posted : 03/09/2020 9:17 pm
