1/2" bending b...
[Closed] 1/2" bending beam torque wrench - where?
Im looking for a 1/2" drive bending beam torque wrench with a ft/lb scale on( i realise i can convert both the drive and the torque figure but why buy the wrong thing)
I only need 18ft/lbs but it cant be a clicky type wrench.
How ever when it comes to bending beam wrenches i can only find bargain basement 12.99 draper stuff - the park 3/8s "nm/inchpound" scale or 200 quid jobs.
Are there any middle of the road items that are not just rebadged 12.99 jobs ?
Or is it simply down to ease of manufacture and they are indeed worth about 12.99 to make.
http://www.amazon.co.uk/Draper-34487-2-Inch-Square-A-Type/dp/B0001K9T24
is the cheapo and ive seen the park tw2 for 40 quid which is the wrong drive and wrong scale how ever - its much smaller "range" - 0-50 ft lbs and in my mind more likely to be accurate than a 12.99 0-180 ft lb wrench ?
Posted : 13/05/2015 4:11 am
I have one but I can't think of the name of the manufacturer. I'll find out and post later.
Posted : 13/05/2015 6:22 am
cheers appreciate it as bending beam torque wrench into google doesnt seem to give many options barring super cheap and super expensive , and the mad part is they look the same.
Posted : 13/05/2015 6:48 am
They are called deflection torque wrenches
if your wanting one for Landrover timing belts for example - you can use the clicker type but practise with it until you know exactly where the 'click' happens.
Otherwise get yourself a dialtype torque wrench-similiar function to a deflection type but more accurate.
Posted : 13/05/2015 7:50 am
Honest question: are the clicky type not accurate then?
Posted : 13/05/2015 8:13 am
yes clicker types are accurate but not suitable for certain applications-and dont know the OPs application but for example on Defender engines you use a deflection or dial type torque wrench to put a certain amount of tension on the timing belt idler/adjuster before then locking it down in place.
It [i]is[/i] possible to use clicker/breaker type torque wrenches in this situation but it needs practise and familiarity of the 'breaking' point of your wrench. Better to use a dial type.
Posted : 13/05/2015 12:09 pm
RNP is on it like a john deere bonnet
my 200tdi needs a timing belt before i dare take it for an MOT.
Posted : 13/05/2015 12:31 pm
I've gone with the Park one + an adaptor to take it up to 1/2".
If you can wait I'll give you a lend.
All the 1/2" ones have far too small a scale to be useful at 15 Nm or whatever the tensioner needs.
EDIT: when I did the old 300tdi I just duct taped a kitchen scale to a 1/2" breaker bar, M=Fd and bob's your uncle. Certainly the cheapest way.
Couldn't be arsed with the faff this time around though...
Posted : 13/05/2015 12:38 pm
i can wait .....
im currently here
13°52'46.44"S
123°19'4.33"E
and im not joking 😀
how ever it will be cheaper both price and time to just buy the thing so its sitting at my house when i get back as i have 3 weeks from when i get back to have a stagger , get the landy through an mot and get my arse to my wedding !
Posted : 13/05/2015 2:43 pm
