SRAM GX Eagle Trans...
SRAM GX Eagle Transmission Review Update
When the dust finally settled on the X0 and XX1 versions, the SRAM GX Eagle Transmission arrived, aimed much more at regular mortals.
By ben_haworth
Get the full story here:
https://singletrackworld.com/2024/02/sram-gx-eagle-transmission-review/
Posted : 15/02/2024 8:01 am
They've changed the direct mount chainring interface by the looks of it which is a pain.
Posted : 11/07/2023 4:10 pm
kelvin reacted
You don’t get the Magic Pulley
It does feel like a gimmick anyway. Plus, as I now have a bike that will accommodate T series, a story about new GX AXS is still not helping in my quest to not buy AXS. I'd appreciate it if you never speak of this again. Thanks.
Posted : 11/07/2023 4:13 pm
powerbenny reacted
That crankset is ugly. Otherwise, looks like a decent groupset and I see no reason to go with anything higher.
Posted : 11/07/2023 4:14 pm
powerbenny and dc1988 reacted
dc1988
They’ve changed the direct mount chainring interface by the looks of it which is a pain.
8 bolt ones have been around for a while on their road kit, but yes, the 3-bolt system didn't seem broke
Posted : 11/07/2023 4:30 pm
kelvin reacted
They've changed almost everything - flat top chain with the bigger rollers means cassette incompatibility too. I mean, it's now compatible with the Road stuff, but other than locking everyone in to them I really don't know why they had to fiddle with the chain.
kelvin reacted
The 8-bolt thing is apparently to accomodate power meters
Posted : 11/07/2023 4:32 pm
They’ve changed almost everything – flat top chain with the bigger rollers means cassette incompatibility too.
Isn't cassette incompatibility a given as "T-type" kit is spaced wider?
Posted : 11/07/2023 5:14 pm
kelvin reacted
 DrP
presumably the 12 speed cassette spacing is always the same? just the 'start - finish position trim' changes?
Dunno...i'll look into that...
I'd hapily try one of the t type derailers if that's ALL i need to buy... I've got a shifter/chain/cassette that are fine!
DrP
Posted : 11/07/2023 5:20 pm
presumably the 12 speed cassette spacing is always the same? just the ‘start – finish position trim’ changes?
Dunno…i’ll look into that…
I thought part of the reason they did it was that by dictating exactly where the cassette and derailleur are in relation to each other they could effectively use that last few mm of dead space between the cassette and the dropout? i.e. the bit of a boost hub that used to measure 141mm (excluding the bit that sit inside the dropout) can now be slightly wider as they don't have to allow for frame designers doing their own thing with dropout shapes.
Posted : 11/07/2023 5:29 pm
kelvin reacted
Massive reductions in price by the new year do we think? That's when I'll pick it up, minus the cranks.
Posted : 11/07/2023 10:57 pm
So will Salsa be able to produce an Alternator dropout for this?
Posted : 12/07/2023 12:46 am
Those cranks (and to a lesser extent the rear mech) make it look like a Duplo Transmission to me 🙂
Posted : 12/07/2023 9:06 am
kelvin, sillyoldman, powerbenny and 1 people reacted
At £1180, I’d say it’s almost reasonable enough for me finally to make the jump across to electronic gearing. I really want to. But having to buy a new frame to hang it off?
Sorry SRAM, but I’m out.
Posted : 12/07/2023 11:43 am
kelvin and powerbenny reacted
Surely you can pick up a full GX AXS groupset for less than that without having to resort to the new version?
Posted : 12/07/2023 11:46 am
kelvin reacted
I've got a compatible frame, and think that when my chain ring and cassette go, I'll be upgrading.
The idea of not having to keep replacing derailleur hangers and shift cables is very tempting.
Posted : 12/07/2023 11:54 am
reckon around £600 with some deal hunting. Upgrade kit is sub £400 on sale, cassette & chain ~£200
Posted : 12/07/2023 12:14 pm
Have they done anything to fix the lag between presssing the sifter button and the electronics deciding it’s lined up and will actually shift gear. There are loads of videos showing how much slower T type AXS shift compared to normal AXS that none of the journos are commenting on for some reason
Posted : 12/07/2023 2:36 pm
It's mentioned by Ben in the write up above.
Posted : 12/07/2023 2:48 pm
powerbenny and chipps reacted
thats what i am hoping too!
Posted : 12/07/2023 11:14 pm
I have sliding dropouts
Posted : 12/07/2023 11:15 pm
The GX AXS is an option, yes, absolutely. But how long are Sram going to support it, given they’ll be wanting folk to go for their flagship UDH system?
Posted : 16/07/2023 10:42 am
I’d say that there’s going to be decent market for non UDH derailleurs for quite some time yet.
Posted : 16/07/2023 11:24 am
kelvin reacted
