UPDATED | Orange Bi...
UPDATED | Orange Bikes Calls In Administrators
This looks more like the price they should've been all along: https://startfitness.co.uk/collections/orange/products/orange-switch-7-pro-moutain-bike-2023-orange
Posted : 22/01/2024 11:18 am
Simon and Simon reacted
Cheap but no warranty potentially. Tough call
Posted : 22/01/2024 11:21 am
Is the warranty not with the place you bought it? If so, surely they'd be doing the warranty...if Orange goes completely then there could be an issue...
Posted : 22/01/2024 3:51 pm
kelvin and kelvin reacted
by the way Orange's website has been down now for 2 weeks... anyone got an update ? i made an order the day before the site shutdown and it arrived fine but i wonder how long their site can remain down and if they can come back ?
Posted : 22/01/2024 7:12 pm
DickBarton
Is the warranty not with the place you bought it? If so, surely they’d be doing the warranty…if Orange goes completely then there could be an issue…
It's added hassle though. Buy a bike and have no idea what'll happen if it cracks in 18months time - not ideal. I'm sure* Start would try and look after you, but you could be stuck with something you don't want.
*never had any dealings with them, but never seen gripes either
Posted : 22/01/2024 7:53 pm
Always a sad state of affairs if you buy things based on a warranty as you are buying something you are expecting to fail...if that is the case, buy something that is more reliable.
Posted : 22/01/2024 9:42 pm
fruitbat and fruitbat reacted
There does seem to actually be much stock at start fitness. Add a bike to your cart and then try to add more, it'll tell you that you have all 1 or 2 of them already.
Posted : 23/01/2024 12:51 pm
 mert
These days bearings are much better so lots of them is less of an issue
What? The sort of bearings that you use in bikes haven't changed significantly in decades.
Posted : 23/01/2024 2:27 pm
Always a sad state of affairs if you buy things based on a warranty as you are buying something you are expecting to fail…if that is the case, buy something that is more reliable.
You're not buying a £30 kettle, but thousands of pounds worth of bike. I'd want a warranty. And with the best will in the world Start Fitness won't be setting up a warehouse full of Orange spare parts 'just in case'.
Posted : 23/01/2024 2:38 pm
That's not an argument - even "reliable" things come with a warranty; it's basic consumer law.
Posted : 23/01/2024 2:48 pm
footflaps and footflaps reacted
What? The sort of bearings that you use in bikes haven’t changed significantly in decades.
Some FS bikes have really good sealing these days.
But by no means all.
Posted : 23/01/2024 3:34 pm
mert
True but most brands have moved away from stupid tiny ones, and sealing/protection has seemed to improve pretty much across the board. DEATH TO 608 BEARINGS. But, I even remember stuff like manufacturers fitting single sided seals "to reduce drag", absolute bloody madness.
I'm not sure if this is a "bikes getting better" or "bikes getting bigger and more capable so you don't generally have to make a song and dance about 2 grams or 3 watts any more".
Posted : 23/01/2024 8:02 pm
I'd be wanting a warranty as well, and as I've asked above, you would have one buy buying from Start...would you not?
If something went wrong then it would be you and Start that the warranty claim goes through - either Start goes to Orange or something else if Orange isn't around. So I think it is odd people are saying there won't be a warranty, I think there will be.
I'm all for warranties, they make a lot of sense, but unless you are buying direct from Orange, then you will have a warranty if they go pop (or until the warranty expires) - should you not?
Posted : 23/01/2024 8:23 pm
 mert
So bearings have changed not one iota.
Idiots sourcing and speccing the bearings have actually done it properly.
Posted : 23/01/2024 9:33 pm
You've never seen an XDR freehub. The outer bearing size is constrained by being small enough to fit inside a 10 sp sprocket and wide enough to fit over a 12mm through axle, 2.2 mm bearings IIRC. I regularly have mine collapsing on me on all my road bikes, am now very adept at swapping bearings in 'non-servicable' free hubs!
Posted : 23/01/2024 9:37 pm
I’d be wanting a warranty as well, and as I’ve asked above, you would have one buy buying from Start…would you not?
Would you though, if Orange go under? You'd be covered by the CRA, but how do you expect them to honour something offered by an entity that no longer exists?
Posted : 23/01/2024 9:47 pm
We were talking about frame bearings which don't have such constraints.
But is it not just the same as the XD, a 6802? I've got on fine with my xd freehubs, it's not weight bearing after all and it's reasonably shielded behind the endcap
Posted : 23/01/2024 9:49 pm
they could honour it, but you might find that man’s getting offered an equivalent from another brand that you might not want
Posted : 23/01/2024 9:57 pm
Selling up shop! That does mean that warranty is now good will only for what it's worth. Hopefully they find a buyer.
Posted : 24/01/2024 10:38 am
Not trading whilst in administration. I don't have a good understanding of the process but that makes the situation sound at the poorer end of bad, sad reading.
Posted : 24/01/2024 10:40 am
Sad they couldn't restructure and continue.
Hopefully a sympathetic and enthusiastic buyer will be found, but it's a bit of an unusual setup with the factory sort-of separate.
Who might consider stepping in? Hope perhaps?
Posted : 24/01/2024 11:02 am
Does seem like they aren't going to just sell off some stuff and get back on top of it.
Unless there is an employee buyout or something similar my guess is this is going to be dumping all of the existing stock to companies that specialise in liquidations to pay debts then selling the Orange name to the highest bidder.
I think there will be an "Orange" in the future but it won't be anything related to the current Orange.
Really selfish but I sort of hope the remaining frame stock turns up for good prices on ebay or something so that owners (myself included) can pick up spares as the 5 year warranty isn't good for much anymore.
Posted : 24/01/2024 11:22 am
I've always been a bit puzzled about that, as the trademark seems to be owned by the phone company. I can remember Michael Bonney telling me something about it, but I can't remember what.
https://trademarks.ipo.gov.uk/ipo-tmcase/page/Results/1/UK00908656464
Posted : 24/01/2024 11:42 am
I thought it was ok to have the same trademark as long as products/services didn't overlap? So - Apple Music/Apple Computers (though that went a bit weird) and Pact Coffee /Pact Bikes?
Posted : 24/01/2024 11:51 am
I'm sure it's all legit! I think there was some legal agreement about their right to use them.
But it's fascinating* that the Orange Phone people have actually got the Orange bike logos registered to them, rather than Orange Mountainbikes/Bairstows.
*Not that fascinating.
Posted : 24/01/2024 11:55 am
I’ve always been a bit puzzled about that, as the trademark seems to be owned by the phone company.
Orange bikes would have a trademark for the word orange with their colour, style etc within the business of
selling bikes and Orange phones would have their own trademark but for the business of selling phones.
I don't think anyone would buy the Orange brand and suddenly use it to market a phone company.. but you never know.
Posted : 24/01/2024 11:59 am
A few people on some of the Facebook groups reckon they had had some positive sounding messages from some of the staff on tech or customer support emails hinting that there was, at least, some sort of plan in place.
Fingers crossed there is something being planned behind closed doors.
Posted : 24/01/2024 12:00 pm
The spectre of Ashley looms!
Posted : 24/01/2024 12:03 pm
selling bikes
You would think so, but the only TM I can find they own is STRANGE
https://trademarks.ipo.gov.uk/ipo-tmowner/page/search?id=1313494&domain=1
Posted : 24/01/2024 12:06 pm
I don’t think anyone would buy the Orange brand and suddenly use it to market a phone company.. but you never know.
orange telco. probably bought them from Orange bike co. then licensed it back to them for a £1 in order to tidy up the IP surrounding the Orange name.
Posted : 24/01/2024 12:44 pm
Websites back.
statement from Orange on pb.
We're still here and our customer service team are still at Orange to take any calls or enquiries from the public or dealers and they have been doing so since we entered administration. There's good news on the horizon and hopefully we'll be able to update everyone soon. We appreciate everyone's support throughout this process and we're looking forward to getting back to normal ASAP.
Posted : 26/01/2024 4:27 pm
stevie750, kelvin, stevie750 and 1 people reacted
Posted : 26/01/2024 4:51 pm
ORANGE
Posted : 26/01/2024 6:10 pm
Panic over
edit: beaten to it
Posted : 26/01/2024 6:11 pm
Panic over!
Thanks for sticking with us!
After restructuring of the business and its associated companies we are pleased to announce that Orange Bikes is set to continue under Ash Ball.
What does this mean?
In simple terms, we’ve strengthened our position to make us more stable, we have plans to move the entire team to its own bespoke location – from welding to marketing and everything in between we will be under one roof for the first time in our history.
Posted : 26/01/2024 6:15 pm
Houns and Houns reacted
Panic over!
Yep just got an email from orange.
Good news
Posted : 26/01/2024 6:18 pm
Great news and by the sounds of things, they are going bigger so surely better.
Posted : 26/01/2024 6:21 pm
Great news. Crack open a beer...
Posted : 26/01/2024 6:25 pm
https://www.pinkbike.com/news/orange-p7-gets-the-mx-treatment-and-updates-for-29-and-275-frames.html
18 new SKUs for a relatively niche hardtail - three wheel size variants, most available in four sizes and some in two colours. They're not learning, are they?
Posted : 02/02/2026 12:13 pm
Del reacted
What awful product publicity shots at the start of that article! Are they ashamed of it? Looks like they used the under stairs cupboard as the photo studio.
Posted : 02/02/2026 1:23 pm
Del reacted
Also full 27.5 feels mad in this day & age - I think Cotic's approach on the BFe is more sensible with the double decker dropout for MX curious riders.
Del reacted
Posted by: PrinceJohn
My next bike will be 27.5.
I was planning on getting a Marino custom build but if a P7 does the job then that makes more sense.
But I'm a bit weird...
Posted : 02/02/2026 1:44 pm
nicko74 reacted
Never owned an orange but I remember a week after buying my rock hopper I went to glentress. My mate didn't have a bike so hired an orange 6. I had a shot, drove home, sold the rock hopper the same day, and bought myself a heckler (I couldn't afford an orange)
The looks never really appealed, but that orange 6 was a phenomenal bike and is pretty much entirely to blame for me spending many thousands of pounds since on bike kit..
Glad they will keep going.
Posted : 02/02/2026 2:24 pm
DJI motors? Like the one they attached last year?
Posted : 02/02/2026 2:30 pm
Page 10 / 11
