Zee brakes and SRAM...
[Closed] Zee brakes and SRAM shifters
[#6320485]
I just bought some Zee brakes from CRC for the Missus and have tried to mount them on her bars with a reverb remote(grrr!) and SRAM X9 shifters in the same way I managed with mine. But her hands are to small to be able to use all 3. She was ok when she had Elixers as I could mount the shifters on the same clamp as the brakes. I've seen the Problem Solver Mismatch Makers which look like they'd do the trick but need to know if the Zee brakes are I Spec or B Spec. How do you tell or does anyone know the answer?
Ta
Tom
Posted : 06/07/2014 8:44 pm
Printed on the levers should be a part number post it up, and should be able to crack it from that.
Posted : 06/07/2014 9:35 pm
If the model number found on the lever ends with a B, it's i-spec B.
Posted : 06/07/2014 9:47 pm
