boring, but essenti...
[Closed] boring, but essential 3-speed shifter question...
[#6320492]
I want to get back on my bike, but my LH 3-speed shifter for my 3 x 9 xt set-up has just seized up after 7 years of otherwise faultless service
Is the left hand version of the following going to provide 3-speed or just 9-speed for the LH to use??
Shimano XT M770 9 Speed Trigger Shifter - http://www.chainreactioncycles.com/shimano-xt-m770-9-speed-trigger-shifter/rp-prod20701
Thanks for taking the time to respond
Posted : 06/07/2014 8:52 pm
LH is 3 speed only
RH is 9 speed only....
but I'm pretty sure you could use almost any LH shimano shifter as the front chain ring spacing will be the same for 9 or 10 speed.
Posted : 06/07/2014 9:01 pm
It'll be 3 speed, it's just labelled as part of a 9sp set-up.
Posted : 06/07/2014 9:02 pm
Flyingmm have you checked it's definitely dead? I had some 15 year old stx-rc shifters that I managed to resuscitate by taking apart completely and simply cleaning (I'm mechanically inept too)
Posted : 06/07/2014 9:07 pm
Thanks folks. Yep, taken them apart superstu and feels like grime is part of the problem, but mainly the spring seems knackered - I'm having to pull the lever back
Posted : 06/07/2014 9:38 pm
Worth just attacking it with degreaser of choice and see what happens?
Posted : 06/07/2014 10:39 pm
 gogg
I squirted some Muc-Off "Disc Cleaner" into a "stuck" shifter, worked fine again after that, just flushed some of the accumulated crap from the grease.
Posted : 07/07/2014 9:17 am
