YT Wicked
[Closed] YT Wicked
4 Users
Have just bought a used Wicked 650b frame and can't seem to find a few bits of info I need online. Basically just want to know if it can safely take a 203mm rear disc brake and what size disc the post mount on the frame fits without an adapter on it? Also I assume it's a 30.9mm seatpost?
Posted : 04/07/2016 1:27 pm
Hang on, I have one in the shed - let me check it
Posted : 04/07/2016 1:30 pm
Is it the 2014 650b?
If so, comes with 200mm rotors and yes 30.9 seatpost
[url= http://www.vitalmtb.com/product/guide/Bikes,3/YT/Wicked-650b-Pro,14557 ]YT Wicked[/url]
Posted : 04/07/2016 1:35 pm
30.9 with 34.9 clamp
135x12 rear end
215x63 shock giving 158mm travel
I ran a 203 rotor but had to use a combination of washers to get the desired fit...i went back to a 180 as its plenty in all honesty and you dont need an adapter.
From what i found..the easiest waybto.run 200 was using avid brakes and their adapters
Posted : 04/07/2016 1:36 pm
Should have said it's a 2013 afaik. Thanks for the info 🙂 I'll prob just get a 180 rotor if it means faffing about with washers to get it to fit right.
Posted : 04/07/2016 1:38 pm
As above, measured the one in the shed and it's 30.9 (30.95 on my calipers, tolderance fans)
Rear rotor is 200mm Avid with XO calipers using a +20PM Adapter and a bunch of wshers
