Yeti 575 Frame/SRAM...
[Closed] Yeti 575 Frame/SRAM XO Rear Mech Problem
Hi
Have a query about fitting a SRAM XO rear mech on a Yeti 575 frame (not mine, alas).
The SRAM manual is very clear on the exact length of cable/housing after the last stop on the frame. The Yeti manual is clear that you use fully sheathed cable all the way down so you obviously can't run a specific length after the last cable stop.
What gives? ๐Ÿ˜ฏ
Posted : 21/05/2010 11:50 pm
Same setup as mine, which runs a full outer with no probs at all!
Posted : 22/05/2010 12:21 am
Cool, thanks.
I'll give it a go and not worry about the length of the last bit too much ๐Ÿ™‚
Posted : 22/05/2010 1:41 am
Using a full outer you can run the risk of having some sticky gears but a good quality cable and outer will solve that and since its a full outer it sould last a bit longer since its harder for crap to get in there.
Posted : 22/05/2010 7:43 am
